[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2018-07-16
Kong, Fande
fande.kong at inl.gov
Mon Jul 16 12:35:31 CDT 2018
Updated PR for fixing these warnings.
https://bitbucket.org/petsc/petsc/pull-requests/1033/add-more-apis-to-mathypre/diff
Satish, could you help me add changes to next for testing?
Fande,
On Mon, Jul 16, 2018 at 10:54 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> On Mon, Jul 16, 2018 at 10:53 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
>> On Mon, Jul 16, 2018 at 10:45 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/07
>>> /16/filtered-make_next_arch-linux-pkgs-64idx_thrash.log
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_filtered-2Dmake-5Fnext-5Farch-2Dlinux-2Dpkgs-2D64idx-5Fthrash.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=Tex32jmZol07NSKHedEY1vMAOU3X5Wwo3h0QksHN9iA&e=>
>>> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:1089:9:
>>> warning: passing argument 3 of ‘HYPRE_IJMatrixAddToValues’ from
>>> incompatible pointer type [enabled by default]
>>> warning: passing argument 5 of ‘HYPRE_IJMatrixAddToValues’ from
>>> - PetscScalar sscr[MATHYPRE_SCRATCH];
>>> - HYPRE_Int cscr[2][MATHYPRE_SCRATCH];
>>> - HYPRE_Int i,nzc;
>>> + PetscScalar *sscr;
>>> + PetscInt *cscr[2];
>>> + PetscInt i,nzc;
>>> + void *array;
>>> PetscStackCallStandard(HYPRE_IJMatrixAddToValues,(hA->ij,1,&
>>> nzc,(HYPRE_Int*)(rows+i),cscr[0],sscr));
>>> So 'nzc' and 'cscr' types got changed from HYPRE_Int to PetscInt -
>>> causing this problem.
>> I fixed it in my branch, and I will push up soon.
>>> And this code is wierd..
>>> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt size, void
>>> **array)
>>> + Mat_HYPRE *hA = (Mat_HYPRE*)A->data;
>>> + PetscFunctionBegin;
>>> + *array = NULL;
>>> + size = 0;
>>> + hA->available = PETSC_TRUE;
>>> + PetscFunctionReturn(0);
>>> Why does this routine need 'size' argument?
>>> + size = 0;
>>> This is just a local variable - setting it to 0 does not do anything..
>> In order to have make MatRestoreArray_HYPRE and MatRestoreArray_HYPRE
>> looks same. If did not do anything to size and array, and then we may have
>> some warnings: unused parameters.
> MatRestoreArray_HYPRE and MatGetArray_HYPRE
>> Should we do something like this?
>> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt /*size*/,
>> void **/*array*/)
>> Not sure C89 like this or not. If you have any idea, please let me know
>> Fande,
>>> /16/filtered-make_next_arch-freebsd-cxx-pkgs-opt_wii.log
>>> /usr/home/balay/petsc.next-2/src/mat/impls/hypre/mhypre.c:1075:20
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_filtered-2Dmake-5Fnext-5Farch-2Dfreebsd-2Dcxx-2Dpkgs-2Dopt-5Fwii.log_usr_home_balay_petsc.next-2D2_src_mat_impls_hypre_mhypre.c-3A1075-3A20&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=MdGPEX6870uF0YUQJdQLQ89XEaJJMULBnSTH_3qHW4s&e=>:
>>> warning: 'array' may be used uninitialized in this function
>>> [-Wmaybe-uninitialized]
>>> /16/filtered-make_next_arch-linux-opt-misc_el6.log
>>> /home/sandbox/petsc/petsc.next/src/mat/impls/hypre/mhypre.c:1103:53
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_filtered-2Dmake-5Fnext-5Farch-2Dlinux-2Dopt-2Dmisc-5Fel6.log_home_sandbox_petsc_petsc.next_src_mat_impls_hypre_mhypre.c-3A1103-3A53&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=XiGTAXejawPngic6-Hokaz5MestYv5_4LDPTBoQzIfU&e=>:
>>> warning: ‘array’ may be used uninitialized in this function
>>> This is a bit wierd. Different builds are giving warnings at different
>>> lines. And not all builds are warning about this.
>>> /16/next.html
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_next.html&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=iKNI8CQTR2xSXVHJo2bm9e4FIGKEgEiN1GpVYH-P9v4&e=>
>>> So - it must be the compiler/os combination.. I'll have to take a closer
>>> look..
>>> Satish
>>> On Mon, 16 Jul 2018, Matthew Knepley wrote:
>>> > On Mon, Jul 16, 2018 at 11:38 AM Fande Kong <fdkong.jd at gmail.com>
>>> wrote:
>>> > > Hi Satish and Barry,
>>> > > Any way to reproduce these warnings? I just tried the same configure
>>> > > script on my desktop, and I did NOT see any warning.
>>> > You would need the same compiler/options. Is it not clear why they
>>> happen?
>>> > Matt
>>> > > Fande,
>>> > > On Mon, Jul 16, 2018 at 6:28 AM, PETSc checkBuilds <
>>> > > petsc-checkbuilds at mcs.anl.gov> wrote:
>>> > >> Dear PETSc developer,
>>> > >> This email contains listings of contributions attributed to you by
>>> > >> `git blame` that caused compiler errors or warnings in PETSc
>>> automated
>>> > >> testing. Follow the links to see the full log files. Please
>>> attempt to
>>> > >> fix
>>> > >> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
>>> are
>>> > >> unable
>>> > >> to resolve the issues.
>>> > >> Thanks,
>>> > >> The PETSc development team
>>> > >> warnings attributed to commit
>>> > >> https://bitbucket.org/petsc/petsc/commits/c69f721
>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__bitbucket.org_petsc_petsc_commits_c69f721&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=5VWpjxoZ9rW530SXMhWQRSPECZA9NhwGhBVHbZBbKLU&e=>
>>> > >> Added MatZeroEntries_HYPRE
>>> /16/build_next_arch-linux-opt-misc_el6.log
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_build-5Fnext-5Farch-2Dlinux-2Dopt-2Dmisc-5Fel6.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=ibtSl72l3tfTct4Jbe9cB8vS_GnqUDc9Nsr4fa6G1rs&e=>
>>> 1103:53:
>>> /16/build_next_arch-linux-pkgs-opt_crank.log
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_build-5Fnext-5Farch-2Dlinux-2Dpkgs-2Dopt-5Fcrank.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=bdrZnwkskWfHXujHM7fKpqskyl-wzH8VC5ir3gp4GPs&e=>
>>> :53:
>>> > >> src/mat/impls/hypre/mhypre.c:1105
>>> /16/build_next_arch-linux-pkgs-64idx_thrash.log
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_build-5Fnext-5Farch-2Dlinux-2Dpkgs-2D64idx-5Fthrash.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=DiGS92uuT24XBHyNgxEDYzIsqrQX5kEChM4esdEi914&e=>
>>> > >> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:11
>>> 05:9:
>>> > >> warning: passing argument 3 of 'HYPRE_IJMatrixSetValues' from
>>> incompatible
>>> 05:9:
>>> > >> warning: passing argument 5 of 'HYPRE_IJMatrixSetValues' from
>>> incompatible
>>> > >> src/mat/impls/hypre/mhypre.c:1524
>>> > >> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:15
>>> 24:5:
>>> > >> warning: assignment from incompatible pointer type [enabled by
>>> default]
>>> > >> src/mat/impls/hypre/mhypre.c:1525
>>> 25:5:
>>> default]
>>> > >> src/mat/impls/hypre/mhypre.c:1582
>>> 82:3:
>>> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixGetRow' from
>>> incompatible
>>> 82:3:
>>> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixGetRow' from
>>> incompatible
>>> > >> src/mat/impls/hypre/mhypre.c:1595
>>> 95:3:
>>> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixRestoreRow' from
>>> 95:3:
>>> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixRestoreRow' from
>>> > >> src/mat/impls/hypre/mhypre.c:1613
>>> > >> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:16
>>> 13:5:
>>> > >> warning: passing argument 3 of 'HYPRE_IJMatrixGetValues' from
>>> incompatible
>>> > >> To opt-out from receiving these messages - send a request to
>>> > >> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180716/47b53e53/attachment-0001.html>
