[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2018-07-16
Satish Balay
balay at mcs.anl.gov
Mon Jul 16 13:19:22 CDT 2018
- void *array;
+ void *array = NULL;
This was the fix for the warnings..
+ ierr = PetscMemzero(array,sizeof(PetscInt)*(2*nc)+sizeof(PetscScalar)*nc*nr);CHKERRQ(ierr);
You don't need this..
Satish
On Mon, 16 Jul 2018, Kong, Fande wrote:
> Updated PR for fixing these warnings.
> https://bitbucket.org/petsc/petsc/pull-requests/1033/add-more-apis-to-mathypre/diff
> Satish, could you help me add changes to next for testing?
> Fande,
> On Mon, Jul 16, 2018 at 10:54 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > On Mon, Jul 16, 2018 at 10:53 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> >> On Mon, Jul 16, 2018 at 10:45 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/07
> >>> /16/filtered-make_next_arch-linux-pkgs-64idx_thrash.log
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_filtered-2Dmake-5Fnext-5Farch-2Dlinux-2Dpkgs-2D64idx-5Fthrash.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=Tex32jmZol07NSKHedEY1vMAOU3X5Wwo3h0QksHN9iA&e=>
> >>> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:1089:9:
> >>> warning: passing argument 3 of ‘HYPRE_IJMatrixAddToValues’ from
> >>> incompatible pointer type [enabled by default]
> >>> warning: passing argument 5 of ‘HYPRE_IJMatrixAddToValues’ from
> >>> - PetscScalar sscr[MATHYPRE_SCRATCH];
> >>> - HYPRE_Int cscr[2][MATHYPRE_SCRATCH];
> >>> - HYPRE_Int i,nzc;
> >>> + PetscScalar *sscr;
> >>> + PetscInt *cscr[2];
> >>> + PetscInt i,nzc;
> >>> + void *array;
> >>> PetscStackCallStandard(HYPRE_IJMatrixAddToValues,(hA->ij,1,&
> >>> nzc,(HYPRE_Int*)(rows+i),cscr[0],sscr));
> >>> So 'nzc' and 'cscr' types got changed from HYPRE_Int to PetscInt -
> >>> causing this problem.
> >> I fixed it in my branch, and I will push up soon.
> >>> And this code is wierd..
> >>> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt size, void
> >>> **array)
> >>> + Mat_HYPRE *hA = (Mat_HYPRE*)A->data;
> >>> + PetscFunctionBegin;
> >>> + *array = NULL;
> >>> + size = 0;
> >>> + hA->available = PETSC_TRUE;
> >>> + PetscFunctionReturn(0);
> >>> Why does this routine need 'size' argument?
> >>> + size = 0;
> >>> This is just a local variable - setting it to 0 does not do anything..
> >> In order to have make MatRestoreArray_HYPRE and MatRestoreArray_HYPRE
> >> looks same. If did not do anything to size and array, and then we may have
> >> some warnings: unused parameters.
> > MatRestoreArray_HYPRE and MatGetArray_HYPRE
> >> Should we do something like this?
> >> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt /*size*/,
> >> void **/*array*/)
> >> Not sure C89 like this or not. If you have any idea, please let me know
> >> Fande,
> >>> /16/filtered-make_next_arch-freebsd-cxx-pkgs-opt_wii.log
> >>> /usr/home/balay/petsc.next-2/src/mat/impls/hypre/mhypre.c:1075:20
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_filtered-2Dmake-5Fnext-5Farch-2Dfreebsd-2Dcxx-2Dpkgs-2Dopt-5Fwii.log_usr_home_balay_petsc.next-2D2_src_mat_impls_hypre_mhypre.c-3A1075-3A20&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=MdGPEX6870uF0YUQJdQLQ89XEaJJMULBnSTH_3qHW4s&e=>:
> >>> warning: 'array' may be used uninitialized in this function
> >>> [-Wmaybe-uninitialized]
> >>> /16/filtered-make_next_arch-linux-opt-misc_el6.log
> >>> /home/sandbox/petsc/petsc.next/src/mat/impls/hypre/mhypre.c:1103:53
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_filtered-2Dmake-5Fnext-5Farch-2Dlinux-2Dopt-2Dmisc-5Fel6.log_home_sandbox_petsc_petsc.next_src_mat_impls_hypre_mhypre.c-3A1103-3A53&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=XiGTAXejawPngic6-Hokaz5MestYv5_4LDPTBoQzIfU&e=>:
> >>> warning: ‘array’ may be used uninitialized in this function
> >>> This is a bit wierd. Different builds are giving warnings at different
> >>> lines. And not all builds are warning about this.
> >>> /16/next.html
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_next.html&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=iKNI8CQTR2xSXVHJo2bm9e4FIGKEgEiN1GpVYH-P9v4&e=>
> >>> So - it must be the compiler/os combination.. I'll have to take a closer
> >>> look..
> >>> Satish
> >>> On Mon, 16 Jul 2018, Matthew Knepley wrote:
> >>> > On Mon, Jul 16, 2018 at 11:38 AM Fande Kong <fdkong.jd at gmail.com>
> >>> wrote:
> >>> > > Hi Satish and Barry,
> >>> > > Any way to reproduce these warnings? I just tried the same configure
> >>> > > script on my desktop, and I did NOT see any warning.
> >>> > You would need the same compiler/options. Is it not clear why they
> >>> happen?
> >>> > Matt
> >>> > > Fande,
> >>> > > On Mon, Jul 16, 2018 at 6:28 AM, PETSc checkBuilds <
> >>> > > petsc-checkbuilds at mcs.anl.gov> wrote:
> >>> > >> Dear PETSc developer,
> >>> > >> This email contains listings of contributions attributed to you by
> >>> > >> `git blame` that caused compiler errors or warnings in PETSc
> >>> automated
> >>> > >> testing. Follow the links to see the full log files. Please
> >>> attempt to
> >>> > >> fix
> >>> > >> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
> >>> are
> >>> > >> unable
> >>> > >> to resolve the issues.
> >>> > >> Thanks,
> >>> > >> The PETSc development team
> >>> > >> warnings attributed to commit
> >>> > >> https://bitbucket.org/petsc/petsc/commits/c69f721
> >>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__bitbucket.org_petsc_petsc_commits_c69f721&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=5VWpjxoZ9rW530SXMhWQRSPECZA9NhwGhBVHbZBbKLU&e=>
> >>> > >> Added MatZeroEntries_HYPRE
> >>> /16/build_next_arch-linux-opt-misc_el6.log
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_build-5Fnext-5Farch-2Dlinux-2Dopt-2Dmisc-5Fel6.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=ibtSl72l3tfTct4Jbe9cB8vS_GnqUDc9Nsr4fa6G1rs&e=>
> >>> 1103:53:
> >>> /16/build_next_arch-linux-pkgs-opt_crank.log
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_build-5Fnext-5Farch-2Dlinux-2Dpkgs-2Dopt-5Fcrank.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=bdrZnwkskWfHXujHM7fKpqskyl-wzH8VC5ir3gp4GPs&e=>
> >>> :53:
> >>> > >> src/mat/impls/hypre/mhypre.c:1105
> >>> /16/build_next_arch-linux-pkgs-64idx_thrash.log
> >>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.mcs.anl.gov_pub_petsc_nightlylogs_archive_2018_07_16_build-5Fnext-5Farch-2Dlinux-2Dpkgs-2D64idx-5Fthrash.log&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=paFK1OY_ndSgoQtSLol9nduqo9lfc1WinXao3N9040w&s=DiGS92uuT24XBHyNgxEDYzIsqrQX5kEChM4esdEi914&e=>
> >>> > >> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:11
> >>> 05:9:
> >>> > >> warning: passing argument 3 of 'HYPRE_IJMatrixSetValues' from
> >>> incompatible
> >>> 05:9:
> >>> > >> warning: passing argument 5 of 'HYPRE_IJMatrixSetValues' from
> >>> incompatible
> >>> > >> src/mat/impls/hypre/mhypre.c:1524
> >>> > >> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:15
> >>> 24:5:
> >>> > >> warning: assignment from incompatible pointer type [enabled by
> >>> default]
> >>> > >> src/mat/impls/hypre/mhypre.c:1525
> >>> 25:5:
> >>> default]
> >>> > >> src/mat/impls/hypre/mhypre.c:1582
> >>> 82:3:
> >>> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixGetRow' from
> >>> incompatible
> >>> 82:3:
> >>> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixGetRow' from
> >>> incompatible
> >>> > >> src/mat/impls/hypre/mhypre.c:1595
> >>> 95:3:
> >>> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixRestoreRow' from
> >>> 95:3:
> >>> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixRestoreRow' from
> >>> > >> src/mat/impls/hypre/mhypre.c:1613
> >>> > >> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:16
> >>> 13:5:
> >>> > >> warning: passing argument 3 of 'HYPRE_IJMatrixGetValues' from
> >>> incompatible
> >>> > >> To opt-out from receiving these messages - send a request to
> >>> > >> petsc-dev at mcs.anl.gov.
