[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2018-07-16
    Fande Kong
    fdkong.jd at gmail.com
    Mon Jul 16 11:54:12 CDT 2018
On Mon, Jul 16, 2018 at 10:53 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> On Mon, Jul 16, 2018 at 10:45 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/
>> 07/16/filtered-make_next_arch-linux-pkgs-64idx_thrash.log
>> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:1089:9:
>> warning: passing argument 3 of ‘HYPRE_IJMatrixAddToValues’ from
>> incompatible pointer type [enabled by default]
>> warning: passing argument 5 of ‘HYPRE_IJMatrixAddToValues’ from
>> -  PetscScalar        sscr[MATHYPRE_SCRATCH];
>> -  HYPRE_Int          cscr[2][MATHYPRE_SCRATCH];
>> -  HYPRE_Int          i,nzc;
>> +  PetscScalar        *sscr;
>> +  PetscInt           *cscr[2];
>> +  PetscInt           i,nzc;
>> +  void               *array;
>> PetscStackCallStandard(HYPRE_IJMatrixAddToValues,(hA->ij,1,&
>> nzc,(HYPRE_Int*)(rows+i),cscr[0],sscr));
>> So 'nzc' and 'cscr' types got changed from HYPRE_Int to PetscInt -
>> causing this problem.
> I fixed it in my branch, and I will push up soon.
>> And this code is wierd..
>> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt size, void
>> **array)
>> +  Mat_HYPRE          *hA = (Mat_HYPRE*)A->data;
>> +  PetscFunctionBegin;
>> +  *array = NULL;
>> +  size = 0;
>> +  hA->available = PETSC_TRUE;
>> +  PetscFunctionReturn(0);
>> Why does this routine need 'size' argument?
>> +  size = 0;
>> This is just a local variable - setting it to 0 does not do anything..
> In order to have make MatRestoreArray_HYPRE and MatRestoreArray_HYPRE
> looks same. If did not do anything to size and array, and then we may have
> some warnings: unused parameters.
MatRestoreArray_HYPRE and MatGetArray_HYPRE
> Should we do something like this?
> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt /*size*/,
> void **/*array*/)
> Not sure C89 like this or not. If you have any idea, please let me know
> Fande,
>> 07/16/filtered-make_next_arch-freebsd-cxx-pkgs-opt_wii.log
>> /usr/home/balay/petsc.next-2/src/mat/impls/hypre/mhypre.c:1075:20
>> <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/07/16/filtered-make_next_arch-freebsd-cxx-pkgs-opt_wii.log/usr/home/balay/petsc.next-2/src/mat/impls/hypre/mhypre.c:1075:20>:
>> warning: 'array' may be used uninitialized in this function
>> [-Wmaybe-uninitialized]
>> 07/16/filtered-make_next_arch-linux-opt-misc_el6.log
>> /home/sandbox/petsc/petsc.next/src/mat/impls/hypre/mhypre.c:1103:53
>> <http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/07/16/filtered-make_next_arch-linux-opt-misc_el6.log/home/sandbox/petsc/petsc.next/src/mat/impls/hypre/mhypre.c:1103:53>:
>> warning: ‘array’ may be used uninitialized in this function
>> This is a bit wierd. Different builds are giving warnings at different
>> lines. And not all builds are warning about this.
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/07/16/next.html
>> So - it must be the compiler/os combination.. I'll have to take a closer
>> look..
>> Satish
>> On Mon, 16 Jul 2018, Matthew Knepley wrote:
>> > On Mon, Jul 16, 2018 at 11:38 AM Fande Kong <fdkong.jd at gmail.com>
>> wrote:
>> > > Hi Satish and Barry,
>> > > Any way to reproduce these warnings? I just tried the same configure
>> > > script on my desktop, and I did NOT see any warning.
>> > You would need the same compiler/options. Is it not clear why they
>> happen?
>> >    Matt
>> > > Fande,
>> > > On Mon, Jul 16, 2018 at 6:28 AM, PETSc checkBuilds <
>> > > petsc-checkbuilds at mcs.anl.gov> wrote:
>> > >> Dear PETSc developer,
>> > >> This email contains listings of contributions attributed to you by
>> > >> `git blame` that caused compiler errors or warnings in PETSc
>> automated
>> > >> testing.  Follow the links to see the full log files. Please attempt
>> to
>> > >> fix
>> > >> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
>> are
>> > >> unable
>> > >> to resolve the issues.
>> > >> Thanks,
>> > >>   The PETSc development team
>> > >> warnings attributed to commit
>> > >> https://bitbucket.org/petsc/petsc/commits/c69f721
>> > >> Added MatZeroEntries_HYPRE
>> 07/16/build_next_arch-linux-opt-misc_el6.log
>> > >> /home/sandbox/petsc/petsc.next/src/mat/impls/hypre/mhypre.c:1103:53:
>> 07/16/build_next_arch-linux-pkgs-opt_crank.log
>> 1103:53:
>> > >>   src/mat/impls/hypre/mhypre.c:1105
>> 07/16/build_next_arch-linux-pkgs-64idx_thrash.log
>> > >>       /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:11
>> 05:9:
>> > >> warning: passing argument 3 of 'HYPRE_IJMatrixSetValues' from
>> incompatible
>> 05:9:
>> > >> warning: passing argument 5 of 'HYPRE_IJMatrixSetValues' from
>> incompatible
>> > >>   src/mat/impls/hypre/mhypre.c:1524
>> > >>       /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:15
>> 24:5:
>> > >> warning: assignment from incompatible pointer type [enabled by
>> default]
>> > >>   src/mat/impls/hypre/mhypre.c:1525
>> 25:5:
>> default]
>> > >>   src/mat/impls/hypre/mhypre.c:1582
>> 82:3:
>> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixGetRow' from
>> incompatible
>> 82:3:
>> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixGetRow' from
>> incompatible
>> > >>   src/mat/impls/hypre/mhypre.c:1595
>> 95:3:
>> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixRestoreRow' from
>> 95:3:
>> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixRestoreRow' from
>> > >>   src/mat/impls/hypre/mhypre.c:1613
>> > >>       /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:16
>> 13:5:
>> > >> warning: passing argument 3 of 'HYPRE_IJMatrixGetValues' from
>> incompatible
>> > >> To opt-out from receiving these messages - send a request to
>> > >> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180716/937599b2/attachment-0001.html>
