[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2018-07-16
    Fande Kong
    fdkong.jd at gmail.com
    Mon Jul 16 11:53:24 CDT 2018
On Mon, Jul 16, 2018 at 10:45 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> 2018/07/16/filtered-make_next_arch-linux-pkgs-64idx_thrash.log
> /sandbox/petsc/petsc.next-3/src/mat/impls/hypre/mhypre.c:1089:9: warning:
> passing argument 3 of ‘HYPRE_IJMatrixAddToValues’ from incompatible
> pointer type [enabled by default]
> passing argument 5 of ‘HYPRE_IJMatrixAddToValues’ from incompatible
> -  PetscScalar        sscr[MATHYPRE_SCRATCH];
> -  HYPRE_Int          cscr[2][MATHYPRE_SCRATCH];
> -  HYPRE_Int          i,nzc;
> +  PetscScalar        *sscr;
> +  PetscInt           *cscr[2];
> +  PetscInt           i,nzc;
> +  void               *array;
> PetscStackCallStandard(HYPRE_IJMatrixAddToValues,(hA->ij,1,
> &nzc,(HYPRE_Int*)(rows+i),cscr[0],sscr));
> So 'nzc' and 'cscr' types got changed from HYPRE_Int to PetscInt - causing
> this problem.
I fixed it in my branch, and I will push up soon.
> And this code is wierd..
> +static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt size, void
> **array)
> +  Mat_HYPRE          *hA = (Mat_HYPRE*)A->data;
> +  PetscFunctionBegin;
> +  *array = NULL;
> +  size = 0;
> +  hA->available = PETSC_TRUE;
> +  PetscFunctionReturn(0);
> Why does this routine need 'size' argument?
> +  size = 0;
> This is just a local variable - setting it to 0 does not do anything..
In order to have make MatRestoreArray_HYPRE and MatRestoreArray_HYPRE looks
same. If did not do anything to size and array, and then we may have some
warnings: unused parameters.
Should we do something like this?
+static PetscErrorCode MatRestoreArray_HYPRE(Mat A, PetscInt /*size*/, void
**/*array*/)
Not sure C89 like this or not. If you have any idea, please let me know
Fande,
> 2018/07/16/filtered-make_next_arch-freebsd-cxx-pkgs-opt_wii.log
> /usr/home/balay/petsc.next-2/src/mat/impls/hypre/mhypre.c:1075:20:
> warning: 'array' may be used uninitialized in this function
> [-Wmaybe-uninitialized]
> 2018/07/16/filtered-make_next_arch-linux-opt-misc_el6.log
> /home/sandbox/petsc/petsc.next/src/mat/impls/hypre/mhypre.c:1103:53:
> warning: ‘array’ may be used uninitialized in this function
> This is a bit wierd. Different builds are giving warnings at different
> lines. And not all builds are warning about this.
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/07/16/next.html
> So - it must be the compiler/os combination.. I'll have to take a closer
> look..
> Satish
> On Mon, 16 Jul 2018, Matthew Knepley wrote:
> > On Mon, Jul 16, 2018 at 11:38 AM Fande Kong <fdkong.jd at gmail.com> wrote:
> > > Hi Satish and Barry,
> > > Any way to reproduce these warnings? I just tried the same configure
> > > script on my desktop, and I did NOT see any warning.
> > You would need the same compiler/options. Is it not clear why they
> happen?
> >    Matt
> > > Fande,
> > > On Mon, Jul 16, 2018 at 6:28 AM, PETSc checkBuilds <
> > > petsc-checkbuilds at mcs.anl.gov> wrote:
> > >> Dear PETSc developer,
> > >> This email contains listings of contributions attributed to you by
> > >> `git blame` that caused compiler errors or warnings in PETSc automated
> > >> testing.  Follow the links to see the full log files. Please attempt
> to
> > >> fix
> > >> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you
> are
> > >> unable
> > >> to resolve the issues.
> > >> Thanks,
> > >>   The PETSc development team
> > >> warnings attributed to commit
> > >> https://bitbucket.org/petsc/petsc/commits/c69f721
> > >> Added MatZeroEntries_HYPRE
> 2018/07/16/build_next_arch-linux-opt-misc_el6.log
> 2018/07/16/build_next_arch-linux-pkgs-opt_crank.log
> > >>   src/mat/impls/hypre/mhypre.c:1105
> 2018/07/16/build_next_arch-linux-pkgs-64idx_thrash.log
> 1105:9:
> > >> warning: passing argument 3 of 'HYPRE_IJMatrixSetValues' from
> incompatible
> 1105:9:
> > >> warning: passing argument 5 of 'HYPRE_IJMatrixSetValues' from
> incompatible
> > >>   src/mat/impls/hypre/mhypre.c:1524
> 1524:5:
> > >> warning: assignment from incompatible pointer type [enabled by
> default]
> > >>   src/mat/impls/hypre/mhypre.c:1525
> 1525:5:
> default]
> > >>   src/mat/impls/hypre/mhypre.c:1582
> 1582:3:
> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixGetRow' from
> incompatible
> 1582:3:
> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixGetRow' from
> incompatible
> > >>   src/mat/impls/hypre/mhypre.c:1595
> 1595:3:
> > >> warning: passing argument 4 of 'HYPRE_ParCSRMatrixRestoreRow' from
> > >> incompatible pointer type [enabled by default]
> 1595:3:
> > >> warning: passing argument 3 of 'HYPRE_ParCSRMatrixRestoreRow' from
> > >>   src/mat/impls/hypre/mhypre.c:1613
> 1613:5:
> > >> warning: passing argument 3 of 'HYPRE_IJMatrixGetValues' from
> incompatible
> > >> To opt-out from receiving these messages - send a request to
> > >> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180716/bcbd4f4f/attachment.html>
