[petsc-dev] Reading periodic meshes from GMSH
    Matthew Knepley
    knepley at gmail.com
    Thu Jul 12 06:25:56 CDT 2018
On Thu, Jul 12, 2018 at 6:20 AM Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> Dear petsc-dev,
> I am attempting to understand how Plex reads GMSH files with
> periodicity.  In particular, what happens to the coordinate localisation.
Stefano wrote this so he will have to help.
> Here's what I expect:
> When reading a periodic mesh, the coordinate section will not only
> associate dofs with mesh vertices, but instead where the "periodic
> boundary" is (at least), the vertices have no dofs associated with
> them, and instead the cell has the coordinate dofs for that cell.
No, I think vertices still have dofs, but only for one side, but this could
have been
changed and I missed it.
> Hence, for a triangular mesh, I expect that for every cell, if I call:
> DMPlexVecGetClosure(dm, coordSection, coords, cell, ...);
> That I will always get back an array with 6 entries.
> However, this is not the case.  For those cells that have been
> identified as periodic, the vertices still have dofs associated with
> them, and so I get back 12 entries when calling VecGetClosure, with
> each coordinate repeated twice.
Yes.
> Am I misunderstanding what's going on?
Yes. If it is periodic, we skip the vertex dofs and just look at the cell
dofs. All the vertex
dofs are still meaningful, they just might not be on the chart that you
want.
    Matt
> Cheers,
> Lawrence
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180712/1134d67f/attachment.html>
