[petsc-dev] My configure is non-working again because of CMake
    Matthew Knepley
    knepley at gmail.com
    Thu Jul  5 17:37:27 CDT 2018
On Thu, Jul 5, 2018 at 5:31 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Well - can you find the version between 3.7 and 3.11 that works on your
> box?
Those bastards do not even have a Changes page. I will have to download
every version and try it.
   Matt
> The previous update was done due to:
> https://bitbucket.org/petsc/petsc/commits/e5b329dd4ac
> No point in going back to having old issues..
> Satish
> On Thu, 5 Jul 2018, Matthew Knepley wrote:
> > On Thu, Jul 5, 2018 at 5:18 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > Logs?
> > I can send it, but its really straightforward. The clang++/g++ on my box
> > (which I will not upgrade because the latest MacOS is crazy)
> > does not have the <unorderedset> header, and thus is not compliant C++11.
> > > And what version of cmake does not require C++11 compliant compiler? We
> > > could downgrade to that..
> > I reverted back to 3.7 which worked, so somewhere in between 3.7 and 3.11
> > they made the change.
> >   Thanks,
> >     Matt
> > > Satish
> > > > Now we require a fully C++11 compliant compiler, or the CMake build
> dies.
> > > > This is crazy.
> > > >    Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180705/7e5a43df/attachment.html>
