[petsc-dev] My configure is non-working again because of CMake
    Satish Balay
    balay at mcs.anl.gov
    Thu Jul  5 17:45:35 CDT 2018
Can you try the following and see if it works for you
./configure PETSC_ARCH=arch-cmake-test --with-mpi=0 --with-sowing=0 --with-fc=0 --download-cmake=https://cmake.org/files/v3.9/cmake-3.9.1.tar.gz
Satish
On Thu, 5 Jul 2018, Matthew Knepley wrote:
> On Thu, Jul 5, 2018 at 5:31 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > Well - can you find the version between 3.7 and 3.11 that works on your
> > box?
> Those bastards do not even have a Changes page. I will have to download
> every version and try it.
>    Matt
> > The previous update was done due to:
> > https://bitbucket.org/petsc/petsc/commits/e5b329dd4ac
> > No point in going back to having old issues..
> > Satish
> > > On Thu, Jul 5, 2018 at 5:18 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > Logs?
> > > I can send it, but its really straightforward. The clang++/g++ on my box
> > > (which I will not upgrade because the latest MacOS is crazy)
> > > does not have the <unorderedset> header, and thus is not compliant C++11.
> > > > And what version of cmake does not require C++11 compliant compiler? We
> > > > could downgrade to that..
> > > I reverted back to 3.7 which worked, so somewhere in between 3.7 and 3.11
> > > they made the change.
> > >   Thanks,
> > >     Matt
> > > > Satish
> > > > > Now we require a fully C++11 compliant compiler, or the CMake build
> > dies.
> > > > > This is crazy.
> > > > >    Matt
