[petsc-dev] snes/ex56 regression
Mark Adams mfadams at lbl.gov
Tue Jul 3 18:24:42 CDT 2018
On Tue, Jul 3, 2018 at 6:26 PM Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >   Runs fine in the master branch;  do you really need it to work in
> maint.
> Uh, many users work with releases.  If this is a "regression" it implies
> that it worked at some point in the past.  In that case, we should fix
> it in 'maint' even if some new feature in 'master' has also fixed it.
> Note that Mark's prompt says he's on 'master', not 'maint'.
Yea, let me double check this.
> >   Barry
> >> On Jul 3, 2018, at 6:39 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >> SNES ex56 seems to have regressed:
> >> 04:35 nid02516 master *=
> ~/petsc_install/petsc/src/snes/examples/tutorials$ make
> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp
> PETSC_ARCH="" runex56
> >> srun -n 1 ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2
> -snes_max_it 2 -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 1000
> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type jacobi
> -petscpartitioner_type simple -mat_block_size 3 -matptap_via scalable
> -ex56_dm_view -run_type 1
> >> OMP: Warning #239: KMP_AFFINITY: granularity=fine will be used.
> >> [0]PETSC ERROR: --------------------- Error Message
> >> [0]PETSC ERROR: Object is in wrong state
> >> [0]PETSC ERROR: Not for unassembled matrix
> >> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> >> [0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-825-g3a11c7608d
> GIT Date: 2018-07-01 06:15:09 +0200
> >> [0]PETSC ERROR:
> /global/u2/m/madams/petsc_install/petsc/src/snes/examples/tutorials/./ex56
> on a  named nid02516 by madams Tue Jul  3 04:35:52 2018
> >> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
> --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
> --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
> --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
> --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
> --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4
> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
> --known-mpi-c-double-complex=1 --known-mklspblas-supports-zero-based=0
> --known-has-attribute-aligned=1 --with-cc=cc --with-cxx=CC --with-fc=ftn
> COPTFLAGS="  -g -O0 -mkl -static-intel" CXXOPTFLAGS="-g -O0 -mkl
> -static-intel" FOPTFLAGS="  -g -O0 -mkl -static-intel" --download-metis=1
> --with-hypre-dir=/global/homes/m/madams/tmp/hypre32-2.14.0
> --download-parmetis=1
> LIBS="-L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64
> -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread"
> --with-blaslapack-include=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/include
> --with-debugging=1 --with-mpiexec=srun --with-batch=1
> --known-mpi-shared-libraries=1 --known-64-bit-blas-indices=0
> --with-64-bit-indices=0 PETSC_ARCH=arch-cori-knl-opt-intel-omp
> --with-openmp=1 --download-p4est=0 --with-x=0
> --prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp
> >> [0]PETSC ERROR: #1 MatConvert() line 4066 in
> /global/u2/m/madams/petsc_install/petsc/src/mat/interface/matrix.c
> >> [0]PETSC ERROR: #2 MatSetType() line 67 in
> /global/u2/m/madams/petsc_install/petsc/src/mat/interface/matreg.c
> >> [0]PETSC ERROR: #3 MatSetFromOptions() line 229 in
> /global/u2/m/madams/petsc_install/petsc/src/mat/utils/gcreate.c
> >> [0]PETSC ERROR: #4 DMCreateMatrix_Plex() line 1137 in
> /global/u2/m/madams/petsc_install/petsc/src/dm/impls/plex/plex.c
> >> [0]PETSC ERROR: #5 DMCreateMatrix() line 1266 in
> /global/u2/m/madams/petsc_install/petsc/src/dm/interface/dm.c
> >> [0]PETSC ERROR: #6 main() line 428 in
> /global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials/ex56.c
> >> [0]PETSC ERROR: PETSc Option Table entries:
> >> [0]PETSC ERROR: -cells 2,2,1
> >> [0]PETSC ERROR: -ex56_dm_refine 0
> >> [0]PETSC ERROR: -ex56_dm_view
> >> [0]PETSC ERROR: -ksp_converged_reason
> >> [0]PETSC ERROR: -ksp_max_it 100
> >> [0]PETSC ERROR: -ksp_monitor_short
> >> [0]PETSC ERROR: -ksp_norm_type unpreconditioned
> >> [0]PETSC ERROR: -ksp_rtol 1.e-11
> >> [0]PETSC ERROR: -ksp_type cg
> >> [0]PETSC ERROR: -mat_block_size 3
> >> [0]PETSC ERROR: -mat_type aijmkl
> >> [0]PETSC ERROR: -matptap_via scalable
> >> [0]PETSC ERROR: -max_conv_its 3
> >> [0]PETSC ERROR: -mg_levels_esteig_ksp_max_it 10
> >> [0]PETSC ERROR: -mg_levels_esteig_ksp_type cg
> >> [0]PETSC ERROR: -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
> >> [0]PETSC ERROR: -mg_levels_ksp_max_it 1
> >> [0]PETSC ERROR: -mg_levels_ksp_type chebyshev
> >> [0]PETSC ERROR: -mg_levels_pc_type jacobi
> >> [0]PETSC ERROR: -pc_gamg_agg_nsmooths 1
> >> [0]PETSC ERROR: -pc_gamg_coarse_eq_limit 1000
> >> [0]PETSC ERROR: -pc_gamg_reuse_interpolation true
> >> [0]PETSC ERROR: -pc_gamg_square_graph 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180703/aab52e7e/attachment.html>
