[petsc-dev] snes/ex56 regression
    Mark Adams
    mfadams at lbl.gov
    Wed Jul  4 08:47:24 CDT 2018
Sorry, this error was with MKL matrices. It is still an error inside of
Plex. My non-Plex tests (KSP) now work in a branch (pushed).
On Tue, Jul 3, 2018 at 7:24 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Jul 3, 2018 at 6:26 PM Jed Brown <jed at jedbrown.org> wrote:
>> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> >   Runs fine in the master branch;  do you really need it to work in
>> maint.
>> Uh, many users work with releases.  If this is a "regression" it implies
>> that it worked at some point in the past.  In that case, we should fix
>> it in 'maint' even if some new feature in 'master' has also fixed it.
>> Note that Mark's prompt says he's on 'master', not 'maint'.
> Yea, let me double check this.
>> >   Barry
>> >> On Jul 3, 2018, at 6:39 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> >> SNES ex56 seems to have regressed:
>> >> 04:35 nid02516 master *=
>> ~/petsc_install/petsc/src/snes/examples/tutorials$ make
>> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp
>> PETSC_ARCH="" runex56
>> >> srun -n 1 ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2
>> -snes_max_it 2 -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
>> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 1000
>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
>> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type jacobi
>> -petscpartitioner_type simple -mat_block_size 3 -matptap_via scalable
>> -ex56_dm_view -run_type 1
>> >> OMP: Warning #239: KMP_AFFINITY: granularity=fine will be used.
>> >> [0]PETSC ERROR: --------------------- Error Message
>> >> [0]PETSC ERROR: Object is in wrong state
>> >> [0]PETSC ERROR: Not for unassembled matrix
>> >> [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> >> [0]PETSC ERROR: Petsc Development GIT revision:
>> v3.9.2-825-g3a11c7608d  GIT Date: 2018-07-01 06:15:09 +0200
>> >> [0]PETSC ERROR:
>> /global/u2/m/madams/petsc_install/petsc/src/snes/examples/tutorials/./ex56
>> on a  named nid02516 by madams Tue Jul  3 04:35:52 2018
>> >> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
>> --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
>> --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
>> --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
>> --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
>> --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4
>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
>> --known-mpi-c-double-complex=1 --known-mklspblas-supports-zero-based=0
>> --known-has-attribute-aligned=1 --with-cc=cc --with-cxx=CC --with-fc=ftn
>> COPTFLAGS="  -g -O0 -mkl -static-intel" CXXOPTFLAGS="-g -O0 -mkl
>> -static-intel" FOPTFLAGS="  -g -O0 -mkl -static-intel" --download-metis=1
>> --with-hypre-dir=/global/homes/m/madams/tmp/hypre32-2.14.0
>> --download-parmetis=1
>> LIBS="-L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64
>> -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread"
>> --with-blaslapack-include=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/include
>> --with-debugging=1 --with-mpiexec=srun --with-batch=1
>> --known-mpi-shared-libraries=1 --known-64-bit-blas-indices=0
>> --with-64-bit-indices=0 PETSC_ARCH=arch-cori-knl-opt-intel-omp
>> --with-openmp=1 --download-p4est=0 --with-x=0
>> --prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp
>> >> [0]PETSC ERROR: #1 MatConvert() line 4066 in
>> /global/u2/m/madams/petsc_install/petsc/src/mat/interface/matrix.c
>> >> [0]PETSC ERROR: #2 MatSetType() line 67 in
>> /global/u2/m/madams/petsc_install/petsc/src/mat/interface/matreg.c
>> >> [0]PETSC ERROR: #3 MatSetFromOptions() line 229 in
>> /global/u2/m/madams/petsc_install/petsc/src/mat/utils/gcreate.c
>> >> [0]PETSC ERROR: #4 DMCreateMatrix_Plex() line 1137 in
>> /global/u2/m/madams/petsc_install/petsc/src/dm/impls/plex/plex.c
>> >> [0]PETSC ERROR: #5 DMCreateMatrix() line 1266 in
>> /global/u2/m/madams/petsc_install/petsc/src/dm/interface/dm.c
>> >> [0]PETSC ERROR: #6 main() line 428 in
>> /global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials/ex56.c
>> >> [0]PETSC ERROR: PETSc Option Table entries:
>> >> [0]PETSC ERROR: -cells 2,2,1
>> >> [0]PETSC ERROR: -ex56_dm_refine 0
>> >> [0]PETSC ERROR: -ex56_dm_view
>> >> [0]PETSC ERROR: -ksp_converged_reason
>> >> [0]PETSC ERROR: -ksp_max_it 100
>> >> [0]PETSC ERROR: -ksp_monitor_short
>> >> [0]PETSC ERROR: -ksp_norm_type unpreconditioned
>> >> [0]PETSC ERROR: -ksp_rtol 1.e-11
>> >> [0]PETSC ERROR: -ksp_type cg
>> >> [0]PETSC ERROR: -mat_block_size 3
>> >> [0]PETSC ERROR: -mat_type aijmkl
>> >> [0]PETSC ERROR: -matptap_via scalable
>> >> [0]PETSC ERROR: -max_conv_its 3
>> >> [0]PETSC ERROR: -mg_levels_esteig_ksp_max_it 10
>> >> [0]PETSC ERROR: -mg_levels_esteig_ksp_type cg
>> >> [0]PETSC ERROR: -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
>> >> [0]PETSC ERROR: -mg_levels_ksp_max_it 1
>> >> [0]PETSC ERROR: -mg_levels_ksp_type chebyshev
>> >> [0]PETSC ERROR: -mg_levels_pc_type jacobi
>> >> [0]PETSC ERROR: -pc_gamg_agg_nsmooths 1
>> >> [0]PETSC ERROR: -pc_gamg_coarse_eq_limit 1000
>> >> [0]PETSC ERROR: -pc_gamg_reuse_interpolation true
>> >> [0]PETSC ERROR: -pc_gamg_square_graph 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180704/7ce13b80/attachment.html>
