[petsc-dev] [petsc-users] Error during PETSc build on Edison
    Amneet Bhalla
    mail2amneet at gmail.com
    Mon Jan 29 22:59:03 CST 2018
It's way too long. The interactive session expired :-(. I think the default
time is ~30 minutes.
I will let it link in a new session and see if that works.
On Mon, Jan 29, 2018 at 8:55 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 30 Jan 2018, Amneet Bhalla wrote:
> > The configure and build worked. When I do make test, it asks to run
> > snes examples manually as nersc does not
> > provide mpiexec command. I tried an interactive session and tried
> building
> > snes/examples/tutorials/ex3
> > % make VERBOSE=1 ex3
> > I am getting stuck at
> Perhaps its taking a long time to link - and you need to wait for it [to
> complete]?
> Satish
> > apbhalla at nid03377:
> > ~/softwares/PETSc-BitBucket/PETSc/src/snes/examples/tutorials$ make
> > VERBOSE=1 ex3
> > cc -O3  -o ex3 ex3.o
> > -L/global/homes/a/apbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
> > -Wl,-rpath,/global/homes/a/apbhalla/softwares/PETSc-
> > -lpetsc -lHYPRE -ldl -lstdc++
> > I am not sure what's going on as there is no return after that.
> > On Mon, Jan 29, 2018 at 8:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > On Tue, 30 Jan 2018, Smith, Barry F. wrote:
> > > >    Master now should not require this horrible flags. Could you do a
> > > > test build with master on edison without these flags and see what
> > > > happens?
> > > It does not work. Will move this thread (with logs) to petsc-maint.
> > > Satish
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180129/7315bca4/attachment-0001.html>
