[petsc-dev] [petsc-users] Error during PETSc build on Edison
    Satish Balay
    balay at mcs.anl.gov
    Mon Jan 29 23:01:31 CST 2018
You should be able to compile/link on the frontend - and then run on the interactive node.
Satish
On Tue, 30 Jan 2018, Amneet Bhalla wrote:
> It's way too long. The interactive session expired :-(. I think the default
> time is ~30 minutes.
> I will let it link in a new session and see if that works.
> On Mon, Jan 29, 2018 at 8:55 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > The configure and build worked. When I do make test, it asks to run
> > > snes examples manually as nersc does not
> > > provide mpiexec command. I tried an interactive session and tried
> > building
> > > snes/examples/tutorials/ex3
> > > % make VERBOSE=1 ex3
> > > I am getting stuck at
> > Perhaps its taking a long time to link - and you need to wait for it [to
> > complete]?
> > Satish
> > > apbhalla at nid03377:
> > > ~/softwares/PETSc-BitBucket/PETSc/src/snes/examples/tutorials$ make
> > > VERBOSE=1 ex3
> > > cc -O3  -o ex3 ex3.o
> > > -L/global/homes/a/apbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
> > > -Wl,-rpath,/global/homes/a/apbhalla/softwares/PETSc-
> > > -lpetsc -lHYPRE -ldl -lstdc++
> > > I am not sure what's going on as there is no return after that.
> > > On Mon, Jan 29, 2018 at 8:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > On Tue, 30 Jan 2018, Smith, Barry F. wrote:
> > > > >    Master now should not require this horrible flags. Could you do a
> > > > > test build with master on edison without these flags and see what
> > > > > happens?
> > > > It does not work. Will move this thread (with logs) to petsc-maint.
> > > > Satish
