[petsc-dev] [petsc-users] Error during PETSc build on Edison
    Satish Balay
    balay at mcs.anl.gov
    Mon Jan 29 22:55:22 CST 2018
On Tue, 30 Jan 2018, Amneet Bhalla wrote:
> The configure and build worked. When I do make test, it asks to run
> snes examples manually as nersc does not
> provide mpiexec command. I tried an interactive session and tried building
> snes/examples/tutorials/ex3
> % make VERBOSE=1 ex3
> I am getting stuck at
Perhaps its taking a long time to link - and you need to wait for it [to complete]?
Satish
> apbhalla at nid03377:
> ~/softwares/PETSc-BitBucket/PETSc/src/snes/examples/tutorials$ make
> VERBOSE=1 ex3
> cc -O3  -o ex3 ex3.o
> -L/global/homes/a/apbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
> -Wl,-rpath,/global/homes/a/apbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
> -lpetsc -lHYPRE -ldl -lstdc++
> I am not sure what's going on as there is no return after that.
> On Mon, Jan 29, 2018 at 8:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Tue, 30 Jan 2018, Smith, Barry F. wrote:
> > >    Master now should not require this horrible flags. Could you do a
> > > test build with master on edison without these flags and see what
> > > happens?
> > It does not work. Will move this thread (with logs) to petsc-maint.
> > Satish
