[petsc-dev] [petsc-users] Error during PETSc build on Edison
    Amneet Bhalla
    mail2amneet at gmail.com
    Mon Jan 29 22:46:18 CST 2018
The configure and build worked. When I do make test, it asks to run
snes examples manually as nersc does not
provide mpiexec command. I tried an interactive session and tried building
snes/examples/tutorials/ex3
% make VERBOSE=1 ex3
I am getting stuck at
apbhalla at nid03377:
~/softwares/PETSc-BitBucket/PETSc/src/snes/examples/tutorials$ make
VERBOSE=1 ex3
cc -O3  -o ex3 ex3.o
-L/global/homes/a/apbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
-Wl,-rpath,/global/homes/a/apbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
-lpetsc -lHYPRE -ldl -lstdc++
I am not sure what's going on as there is no return after that.
On Mon, Jan 29, 2018 at 8:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 30 Jan 2018, Smith, Barry F. wrote:
> >    Master now should not require this horrible flags. Could you do a
> > test build with master on edison without these flags and see what
> > happens?
> It does not work. Will move this thread (with logs) to petsc-maint.
> Satish
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180129/e0fee44b/attachment.html>
