[petsc-dev] test harness loops with different outputs
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Jan 26 09:03:37 CST 2018
> On Jan 26, 2018, at 8:14 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>> There must be something broken in my system as I also get bunch of
>>   /bin/sh: 2: -map: not found
>> errors for
>>   make alldoc LOC=${PETSC_DIR}
>> which means also MAPNAMES is not set.
>> I started from scratch in different PETSc clone and it's the same. Interesting.
> The variables were not set because sowing was not installed. It didn't come to my mind as sowing is not directly related to the PDF manual processing. Damn.
   Yikes, sorry for your wasted time, the makefile in the manual generation directory could/should check that sowing is installed (the variables are set) before trying to build the manual and print a very useful error message if they are not setting telling the person to rerun configure appropriately.
   The reason the manual needs Sowing is that it builds the function index from the index of PETSc functions generated by the rest of documentation building process plus makes links to the manual pages.
   Barry
>> Vaclav
>>> Vaclav
>>>> 2018-01-26 14:00 GMT+01:00 Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>>>> > 25. 1. 2018 v 9:33, Smith, Barry F. <bsmith at mcs.anl.gov>:
>>>> >  src/docs/tex/manual/developers.tex there is also a make file that generates the PDF.
>>>> I'm trying to build the manual. Apparently the PDFLATEX variable is not set. So I set it externally and it works - is it supposed to be done this way? Would you mind adding the PDFLATEX variable into ${PETSC_DIR}/lib/petsc/conf/variables? Perhaps with assigned using ?= so that it could be overridden?
>>>> Vaclav
>>>> >  Barry
>>>> > The document should provide information about the location of its source.
>>>> >> On Jan 25, 2018, at 2:19 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>>>> >>> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com>:
>>>> >>> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
>>>> >>>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>>>> >>>>> How should I specify output files for {{...}} with different outputs, please?
>>>> >>>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
>>>> >>> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
>>>> >> Where are this manual's latex sources?
>>>> >> Vaclav
>>>> >>> Scott
>>>> >>>> Vaclav
>>>> >>>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
>>>> >>>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
>>>> >>>>> Thanks
>>>> >>>>> Vaclav
>>>> >>> Tech-X Corporation               kruger at txcorp.com
>>>> >>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>>>> >>> Boulder, CO 80303                Fax:   (303) 448-7756
