[petsc-dev] new test harness in PETSc
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Wed Jan 24 22:47:57 CST 2018
   PETSc developers,
     We have completed moving all PETSc examples over from the old test system (where tests were written in the makefile) to a new system, provided by Scott Kruger, where the test rules are written in bottom of the source file of the example. Directions for usage and adding new tests can be found in the PETSc developers manual http://www.mcs.anl.gov/petsc/petsc-dev/docs/developers.pdf chapter 7.
  Barry
