[petsc-dev] test harness loops with different outputs
    Vaclav Hapla
    vaclav.hapla at erdw.ethz.ch
    Fri Jan 26 08:14:22 CST 2018
> 26. 1. 2018 v 14:58, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>> 26. 1. 2018 v 14:08, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
>>> 26. 1. 2018 v 14:03, Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>>:
>>> There is probably a better way but what's worked for me here is to make sure I have pdflatex on my system (sudo apt install texlive, or similar), then "make reconfigure", which seems to set PDFLATEX as required, and then something like
>>>      cd src/docs/tex/manual
>>>      make manual.pdf LOC=$PETSC_DIR
>>>      cd ../../../docs
>>>      # manual.pdf should be there
>> Thanks, Patrick. It would be definitely a better way. But I have installed PETSc into Linux with texlive installed and pdflatex command in PATH, and still the PDFLATEX variable hasn't got set.
> There must be something broken in my system as I also get bunch of
>   /bin/sh: 2: -map: not found
> errors for
>   make alldoc LOC=${PETSC_DIR}
> which means also MAPNAMES is not set.
> I started from scratch in different PETSc clone and it's the same. Interesting.
The variables were not set because sowing was not installed. It didn't come to my mind as sowing is not directly related to the PDF manual processing. Damn.
> Vaclav
>> Vaclav
>>> 2018-01-26 14:00 GMT+01:00 Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
>>> > 25. 1. 2018 v 9:33, Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>:
>>> >  src/docs/tex/manual/developers.tex there is also a make file that generates the PDF.
>>> I'm trying to build the manual. Apparently the PDFLATEX variable is not set. So I set it externally and it works - is it supposed to be done this way? Would you mind adding the PDFLATEX variable into ${PETSC_DIR}/lib/petsc/conf/variables? Perhaps with assigned using ?= so that it could be overridden?
>>> Vaclav
>>> >  Barry
>>> > The document should provide information about the location of its source.
>>> >> On Jan 25, 2018, at 2:19 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>> wrote:
>>> >>> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com <mailto:kruger at txcorp.com>>:
>>> >>> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
>>> >>>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
>>> >>>>> How should I specify output files for {{...}} with different outputs, please?
>>> >>>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
>>> >>> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
>>> >> Where are this manual's latex sources?
>>> >> Vaclav
>>> >>> Scott
>>> >>>> Vaclav
>>> >>>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
>>> >>>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
>>> >>>>> Thanks
>>> >>>>> Vaclav
>>> >>> Tech-X Corporation               kruger at txcorp.com <mailto:kruger at txcorp.com>
>>> >>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841 <tel:%28720%29%20974-1841>
>>> >>> Boulder, CO 80303                Fax:   (303) 448-7756 <tel:%28303%29%20448-7756>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180126/e52ea228/attachment.html>
