[petsc-dev] test harness loops with different outputs
    Vaclav Hapla
    vaclav.hapla at erdw.ethz.ch
    Fri Jan 26 07:58:34 CST 2018
> 26. 1. 2018 v 14:08, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>> 26. 1. 2018 v 14:03, Patrick Sanan <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>>:
>> There is probably a better way but what's worked for me here is to make sure I have pdflatex on my system (sudo apt install texlive, or similar), then "make reconfigure", which seems to set PDFLATEX as required, and then something like
>>      cd src/docs/tex/manual
>>      make manual.pdf LOC=$PETSC_DIR
>>      cd ../../../docs
>>      # manual.pdf should be there
> Thanks, Patrick. It would be definitely a better way. But I have installed PETSc into Linux with texlive installed and pdflatex command in PATH, and still the PDFLATEX variable hasn't got set.
There must be something broken in my system as I also get bunch of
  /bin/sh: 2: -map: not found
errors for
  make alldoc LOC=${PETSC_DIR}
which means also MAPNAMES is not set.
I started from scratch in different PETSc clone and it's the same. Interesting.
Vaclav
> Vaclav
>> 2018-01-26 14:00 GMT+01:00 Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
>> > 25. 1. 2018 v 9:33, Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>:
>> >  src/docs/tex/manual/developers.tex there is also a make file that generates the PDF.
>> I'm trying to build the manual. Apparently the PDFLATEX variable is not set. So I set it externally and it works - is it supposed to be done this way? Would you mind adding the PDFLATEX variable into ${PETSC_DIR}/lib/petsc/conf/variables? Perhaps with assigned using ?= so that it could be overridden?
>> Vaclav
>> >  Barry
>> > The document should provide information about the location of its source.
>> >> On Jan 25, 2018, at 2:19 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>> wrote:
>> >>> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com <mailto:kruger at txcorp.com>>:
>> >>> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
>> >>>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
>> >>>>> How should I specify output files for {{...}} with different outputs, please?
>> >>>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
>> >>> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
>> >> Where are this manual's latex sources?
>> >> Vaclav
>> >>> Scott
>> >>>> Vaclav
>> >>>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
>> >>>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
>> >>>>> Thanks
>> >>>>> Vaclav
>> >>> Tech-X Corporation               kruger at txcorp.com <mailto:kruger at txcorp.com>
>> >>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841 <tel:%28720%29%20974-1841>
>> >>> Boulder, CO 80303                Fax:   (303) 448-7756 <tel:%28303%29%20448-7756>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180126/f3e260c3/attachment-0001.html>
