[petsc-dev] test harness loops with different outputs
    Vaclav Hapla
    vaclav.hapla at erdw.ethz.ch
    Fri Jan 26 07:08:34 CST 2018
> 26. 1. 2018 v 14:03, Patrick Sanan <patrick.sanan at gmail.com>:
> There is probably a better way but what's worked for me here is to make sure I have pdflatex on my system (sudo apt install texlive, or similar), then "make reconfigure", which seems to set PDFLATEX as required, and then something like
>      cd src/docs/tex/manual
>      make manual.pdf LOC=$PETSC_DIR
>      cd ../../../docs
>      # manual.pdf should be there
Thanks, Patrick. It would be definitely a better way. But I have installed PETSc into Linux with texlive installed and pdflatex command in PATH, and still the PDFLATEX variable hasn't got set.
Vaclav
> 2018-01-26 14:00 GMT+01:00 Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
> > 25. 1. 2018 v 9:33, Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>:
> >  src/docs/tex/manual/developers.tex there is also a make file that generates the PDF.
> I'm trying to build the manual. Apparently the PDFLATEX variable is not set. So I set it externally and it works - is it supposed to be done this way? Would you mind adding the PDFLATEX variable into ${PETSC_DIR}/lib/petsc/conf/variables? Perhaps with assigned using ?= so that it could be overridden?
> Vaclav
> >  Barry
> > The document should provide information about the location of its source.
> >> On Jan 25, 2018, at 2:19 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>> wrote:
> >>> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com <mailto:kruger at txcorp.com>>:
> >>> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
> >>>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>:
> >>>>> How should I specify output files for {{...}} with different outputs, please?
> >>>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
> >>> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
> >> Where are this manual's latex sources?
> >> Vaclav
> >>> Scott
> >>>> Vaclav
> >>>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
> >>>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
> >>>>> Thanks
> >>>>> Vaclav
> >>> Tech-X Corporation               kruger at txcorp.com <mailto:kruger at txcorp.com>
> >>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841 <tel:%28720%29%20974-1841>
> >>> Boulder, CO 80303                Fax:   (303) 448-7756 <tel:%28303%29%20448-7756>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180126/6793ed88/attachment.html>
