[petsc-dev] test harness loops with different outputs
    Vaclav Hapla
    vaclav.hapla at erdw.ethz.ch
    Fri Jan 26 07:00:39 CST 2018
> 25. 1. 2018 v 9:33, Smith, Barry F. <bsmith at mcs.anl.gov>:
>  src/docs/tex/manual/developers.tex there is also a make file that generates the PDF.
I'm trying to build the manual. Apparently the PDFLATEX variable is not set. So I set it externally and it works - is it supposed to be done this way? Would you mind adding the PDFLATEX variable into ${PETSC_DIR}/lib/petsc/conf/variables? Perhaps with assigned using ?= so that it could be overridden?
Vaclav
>  Barry
> The document should provide information about the location of its source.
>> On Jan 25, 2018, at 2:19 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>>> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com>:
>>> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
>>>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>>>>> How should I specify output files for {{...}} with different outputs, please?
>>>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
>>> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
>> Where are this manual's latex sources?
>> Vaclav
>>> Scott
>>>> Vaclav
>>>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
>>>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
>>>>> Thanks
>>>>> Vaclav
>>> Tech-X Corporation               kruger at txcorp.com
>>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>>> Boulder, CO 80303                Fax:   (303) 448-7756
