[petsc-dev] test harness loops with different outputs
Smith, Barry F. bsmith at mcs.anl.gov
Thu Jan 25 02:33:48 CST 2018
  src/docs/tex/manual/developers.tex there is also a make file that generates the PDF.
  Barry
 The document should provide information about the location of its source.
> On Jan 25, 2018, at 2:19 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com>:
>> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
>>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>>>> How should I specify output files for {{...}} with different outputs, please?
>>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
>> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
> Where are this manual's latex sources?
> Vaclav
>> Scott
>>> Vaclav
>>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
>>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
>>>> Thanks
>>>> Vaclav
>> Tech-X Corporation               kruger at txcorp.com
>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>> Boulder, CO 80303                Fax:   (303) 448-7756
