[petsc-dev] new test harness in PETSc
    Jose E. Roman
    jroman at dsic.upv.es
    Thu Jan 25 02:42:46 CST 2018
Are you going to keep the old makefiles? (I mean ${PETSC_DIR}/lib/petsc/conf/test) In SLEPc we still use makefiles for the tests. I should move to the new system, but don't have time at the moment.
Jose
> El 25 ene 2018, a las 5:47, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>   PETSc developers,
>     We have completed moving all PETSc examples over from the old test system (where tests were written in the makefile) to a new system, provided by Scott Kruger, where the test rules are written in bottom of the source file of the example. Directions for usage and adding new tests can be found in the PETSc developers manual http://www.mcs.anl.gov/petsc/petsc-dev/docs/developers.pdf chapter 7.
>  Barry
