[petsc-dev] new test harness in PETSc
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Thu Jan 25 10:09:20 CST 2018
> On Jan 25, 2018, at 2:42 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> Are you going to keep the old makefiles? (I mean ${PETSC_DIR}/lib/petsc/conf/test) In SLEPc we still use makefiles for the tests.
  Yes
   I have stripped out some stuff like the TESTEXAMPLES_n definitions but we can put back anything you need.
> I should move to the new system, but don't have time at the moment.
> Jose
>> El 25 ene 2018, a las 5:47, Smith, Barry F. <bsmith at mcs.anl.gov> escribió:
>>  PETSc developers,
>>    We have completed moving all PETSc examples over from the old test system (where tests were written in the makefile) to a new system, provided by Scott Kruger, where the test rules are written in bottom of the source file of the example. Directions for usage and adding new tests can be found in the PETSc developers manual http://www.mcs.anl.gov/petsc/petsc-dev/docs/developers.pdf chapter 7.
>> Barry
