[petsc-dev] test harness loops with different outputs
Vaclav Hapla vaclav.hapla at erdw.ethz.ch
Thu Jan 25 02:19:31 CST 2018
> 24. 1. 2018 v 22:55, Scott Kruger <kruger at txcorp.com>:
> On 1/24/18 6:50 AM, Vaclav Hapla wrote:
>>> 24. 1. 2018 v 14:45, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
>>> How should I specify output files for {{...}} with different outputs, please?
>> Oh I see, {{...}separateoutput} is meant literally. But in that case typesetting it in italics is confusing.
> It's clearer in the examples listed below.   I couldn't get lstinline to work for this syntax so used $ ... $.  If someone knows how to do it, please feel free to fix.
Where are this manual's latex sources?
Vaclav
> Scott
>> Vaclav
>>> I have consulted the developers manual but it's not clear to me still. And the example listings, page 34-45, seem to be broken.
>>> BTW in 7.1.2, I think there should be the space instead of the comma in the listing.
>>> Thanks
>>> Vaclav
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
> Boulder, CO 80303                Fax:   (303) 448-7756
