[petsc-dev] SETERRQ in fortran
    Jed Brown
    jed at jedbrown.org
    Fri Jan  5 17:00:53 CST 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>>> On Jan 4, 2018, at 5:10 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>>>>>> On Jan 4, 2018, at 3:16 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>>>>> It's changed a bit.  It is better but you need to understand how the new one works, so take a few minutes to see how it works before converting.
>>>>>> Got it.
>>>>>> An example or a link to the fortran macro definition from the man page would be nice
>>>>>> I am confused about the rationale for putting the endif in the macro, though.
>>>>> It matches the C paradigm
>>>> Hardly.
>>>   It matches the paradigm as close as can be reasonable done.
>>>   I debated putting the then into the macros also.
>>>> #define SETERRQ(c,ierr,s)  then ;call PetscError(c,ierr,0,s);return;endif
>>>   So usage would be
>>>      if (bad) SETERRQ();
>>>  would that be better.
>> No, Fortran isn't C.
>>  if (bad) then
>>      SETERRQ(...)
>>  endif
>> It doesn't get used so much from Fortran that we need to conceal the
>> language constructs.
>    It will, eventually I want all Fortran examples/tests to have checks on every call (like with have in C).
CHKERRQ does the if internally, so it also has the endif.
SETERRA/SETERRQ is used a total of 34 times in 17 Fortran files.
SETERRQ is used a median of zero times and an average of less than 1 in
the C examples.
>>>> This Fortran:
>>>> #define SETERRQ(c,ierr,s)  ;call PetscError(c,ierr,0,s);return;endif
>>>> This would be like writing this C
>>>> #define SETERRQ(c,ierr,s) return PetscError(...); }
>>>> to be used like
>>>> if (BAD) { SETERRQ(comm, ierr, "why")
>>>> which is just bananas and still not as gross as the Fortran.  You might
>>>> not have noticed this because SETERRQ is not called from any of PETSc's
>>>> Fortran examples.
>>>    But SETERRA() is and has the same pattern.
>> It isn't syntactically correct when !defined(PETSC_USE_ERRORCHECKING).
>> The endif isn't going to kill anyone and pulling it out of the macro
>> will make it easier to understand and avoid the circus antics when used
>> in any context other than a positive conditional with no else clause.
>    I'll take this under advisement. Of course in our examples the endif will ALWAYS be on the same line as the rest. Using three lines for a SETERRQ() is ugly.
>>>>>> Beside not having unmatched if / end if in my code, in a select case construct, I have to write something as ugly as
>>>>>> select case (i)
>>>>>> 	case(1)
>>>>>> 		!do something
>>>>>> 	case(2)
>>>>>> 		!do something else
>>>>>> 	case default
>>>>>> 		if (0 == 0) then
>>>>>> 			SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_ARG_OUTOFRANG,”invalid value”)
>>>>>> end select
>>>>> What is ugly about this ? except that you put the SETERRQ on a new line which you did not need to do.
>>>> Reread the above code.  Requiring the dummy opening if statement is nuts.
>>>   Agreed. He should not use SETERRQ() in this case, should call the error functions directly)
>>>>> How do you want to write it so it is prettier?
>>>> SETERRQ should not include that endif.  CHKERRQ has the opening if and
>>>> thus needs the closing too (so it's as intended).  Also note that your
>>>> first reply to Blaise was talking about CHKERRQ when he was asking about
>>>> SETERRQ.
>>>    Hmm, I'm not sure about. Oh well, it doesn't matter. You have convinced me of anything.
