[petsc-dev] SETERRQ in fortran
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Jan 5 17:33:56 CST 2018
> On Jan 5, 2018, at 5:00 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>>>> On Jan 4, 2018, at 5:10 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>>>>>>> On Jan 4, 2018, at 3:16 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>>>>>> It's changed a bit. It is better but you need to understand how the new one works, so take a few minutes to see how it works before converting.
>>>>>>> Got it.
>>>>>>> An example or a link to the fortran macro definition from the man page would be nice
>>>>>>> I am confused about the rationale for putting the endif in the macro, though.
>>>>>> It matches the C paradigm
>>>>> Hardly.
>>>> It matches the paradigm as close as can be reasonable done.
>>>> I debated putting the then into the macros also.
>>>>> #define SETERRQ(c,ierr,s) then ;call PetscError(c,ierr,0,s);return;endif
>>>> So usage would be
>>>> if (bad) SETERRQ();
>>>> would that be better.
>>> No, Fortran isn't C.
>>> if (bad) then
>>> SETERRQ(...)
>>> endif
>>> It doesn't get used so much from Fortran that we need to conceal the
>>> language constructs.
>> It will, eventually I want all Fortran examples/tests to have checks on every call (like with have in C).
> CHKERRQ does the if internally, so it also has the endif.
What is the relevance of this statement.
> SETERRA/SETERRQ is used a total of 34 times in 17 Fortran files.
> SETERRQ is used a median of zero times and an average of less than 1 in
> the C examples.
I am not sure why you are saying this. My resistance to change has nothing to do with how often it is used.
I am leaning to changing it but don't want to until all the test harness branches etc get into master. So it will be a few days.
>>>>> This Fortran:
>>>>> #define SETERRQ(c,ierr,s) ;call PetscError(c,ierr,0,s);return;endif
>>>>> This would be like writing this C
>>>>> #define SETERRQ(c,ierr,s) return PetscError(...); }
>>>>> to be used like
>>>>> if (BAD) { SETERRQ(comm, ierr, "why")
>>>>> which is just bananas and still not as gross as the Fortran. You might
>>>>> not have noticed this because SETERRQ is not called from any of PETSc's
>>>>> Fortran examples.
>>>> But SETERRA() is and has the same pattern.
>>> It isn't syntactically correct when !defined(PETSC_USE_ERRORCHECKING).
>>> The endif isn't going to kill anyone and pulling it out of the macro
>>> will make it easier to understand and avoid the circus antics when used
>>> in any context other than a positive conditional with no else clause.
>> I'll take this under advisement. Of course in our examples the endif will ALWAYS be on the same line as the rest. Using three lines for a SETERRQ() is ugly.
>>>>>>> Beside not having unmatched if / end if in my code, in a select case construct, I have to write something as ugly as
>>>>>>> select case (i)
>>>>>>> case(1)
>>>>>>> !do something
>>>>>>> case(2)
>>>>>>> !do something else
>>>>>>> case default
>>>>>>> if (0 == 0) then
>>>>>>> SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_ARG_OUTOFRANG,”invalid value”)
>>>>>>> end select
>>>>>> What is ugly about this ? except that you put the SETERRQ on a new line which you did not need to do.
>>>>> Reread the above code. Requiring the dummy opening if statement is nuts.
>>>> Agreed. He should not use SETERRQ() in this case, should call the error functions directly)
>>>>>> How do you want to write it so it is prettier?
>>>>> SETERRQ should not include that endif. CHKERRQ has the opening if and
>>>>> thus needs the closing too (so it's as intended). Also note that your
>>>>> first reply to Blaise was talking about CHKERRQ when he was asking about
>>>>> SETERRQ.
>>>> Hmm, I'm not sure about. Oh well, it doesn't matter. You have convinced me of anything.
