[petsc-dev] SETERRQ in fortran
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Jan  5 16:22:55 CST 2018
> On Jan 5, 2018, at 4:18 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>> On Jan 4, 2018, at 5:10 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>>>>>> On Jan 4, 2018, at 3:16 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>>>> It's changed a bit.  It is better but you need to understand how the new one works, so take a few minutes to see how it works before converting.
>>>>> Got it.
>>>>> An example or a link to the fortran macro definition from the man page would be nice
>>>>> I am confused about the rationale for putting the endif in the macro, though.
>>>> It matches the C paradigm
>>> Hardly.
>>   It matches the paradigm as close as can be reasonable done.
>>   I debated putting the then into the macros also.
>>> #define SETERRQ(c,ierr,s)  then ;call PetscError(c,ierr,0,s);return;endif
>>   So usage would be
>>      if (bad) SETERRQ();
>>  would that be better.
> No, Fortran isn't C.
>  if (bad) then
>      SETERRQ(...)
>  endif
> It doesn't get used so much from Fortran that we need to conceal the
> language constructs.
   It will, eventually I want all Fortran examples/tests to have checks on every call (like with have in C).
>>> This Fortran:
>>> #define SETERRQ(c,ierr,s)  ;call PetscError(c,ierr,0,s);return;endif
>>> This would be like writing this C
>>> #define SETERRQ(c,ierr,s) return PetscError(...); }
>>> to be used like
>>> if (BAD) { SETERRQ(comm, ierr, "why")
>>> which is just bananas and still not as gross as the Fortran.  You might
>>> not have noticed this because SETERRQ is not called from any of PETSc's
>>> Fortran examples.
>>    But SETERRA() is and has the same pattern.
> It isn't syntactically correct when !defined(PETSC_USE_ERRORCHECKING).
> The endif isn't going to kill anyone and pulling it out of the macro
> will make it easier to understand and avoid the circus antics when used
> in any context other than a positive conditional with no else clause.
   I'll take this under advisement. Of course in our examples the endif will ALWAYS be on the same line as the rest. Using three lines for a SETERRQ() is ugly.
>>>>> Beside not having unmatched if / end if in my code, in a select case construct, I have to write something as ugly as
>>>>> select case (i)
>>>>> 	case(1)
>>>>> 		!do something
>>>>> 	case(2)
>>>>> 		!do something else
>>>>> 	case default
>>>>> 		if (0 == 0) then
>>>>> 			SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_ARG_OUTOFRANG,”invalid value”)
>>>>> end select
>>>> What is ugly about this ? except that you put the SETERRQ on a new line which you did not need to do.
>>> Reread the above code.  Requiring the dummy opening if statement is nuts.
>>   Agreed. He should not use SETERRQ() in this case, should call the error functions directly)
>>>> How do you want to write it so it is prettier?
>>> SETERRQ should not include that endif.  CHKERRQ has the opening if and
>>> thus needs the closing too (so it's as intended).  Also note that your
>>> first reply to Blaise was talking about CHKERRQ when he was asking about
>>> SETERRQ.
>>    Hmm, I'm not sure about. Oh well, it doesn't matter. You have convinced me of anything.
