[petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
Franck Houssen franck.houssen at inria.fr
Thu Jan 4 11:10:00 CST 2018
Do you reproduce the error at your side ? Or is the pattern I use wrong ?
Franck
----- Mail original -----
> De: "Franck Houssen" <franck.houssen at inria.fr>
> À: "Barry F. Smith" <bsmith at mcs.anl.gov>
> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Jeudi 4 Janvier 2018 09:31:05
> Objet: Re: [petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a
> I attached it in the very first mail.
> Franck
> >> more vecScatterGatherRoot.cpp
> // How do I collect all the values from a sequential vector on the zeroth
> // ~> g++ -o vecScatterGatherRoot.exe vecScatterGatherRoot.cpp -lpetsc -lm;
> mpirun -n X vecScatterGatherRoot.exe
> #include "petsc.h"
> int main(int argc,char **argv) {
>   PetscInitialize(&argc, &argv, NULL, NULL);
>   int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size);
>   int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>   PetscInt globSize = size;
>   Vec globVec; VecCreateMPI(PETSC_COMM_WORLD, 1, globSize, &globVec);
>   VecSetValue(globVec, rank, (PetscScalar) (1.+rank), INSERT_VALUES);
>   VecAssemblyBegin(globVec); VecAssemblyEnd(globVec);
>   VecView(globVec, PETSC_VIEWER_STDOUT_WORLD);
>   PetscViewerFlush(PETSC_VIEWER_STDOUT_WORLD);
>   // Collect all the values from a parallel PETSc vector into a vector on the
>   zeroth processor.
>   Vec locVec = NULL;
>   if (rank == 0) {
>     PetscInt locSize = globSize;
>     VecCreateSeq(PETSC_COMM_SELF, locSize, &locVec); VecSet(locVec, -1.);
>   VecScatter scatCtx; VecScatterCreateToZero(globVec, &scatCtx, &locVec);
>   VecScatterBegin(scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
>   VecScatterEnd  (scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
>   // Modify sequential vector on the zeroth processor.
>   if (rank == 0) {
>     VecView(locVec, PETSC_VIEWER_STDOUT_SELF);
>     PetscViewerFlush(PETSC_VIEWER_STDOUT_SELF);
>     VecScale(locVec, -1.);
>   MPI_Barrier(MPI_COMM_WORLD);
>   VecSet(globVec, 0.);
>   VecScatterBegin(scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
>   VecScatterEnd  (scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
>   PetscFinalize();
> > De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> > À: "Franck Houssen" <franck.houssen at inria.fr>
> > Cc: "Barry F. Smith" <bsmith at mcs.anl.gov>, "Matthew Knepley"
> > <knepley at gmail.com>, "For users of the development
> > Envoyé: Mercredi 3 Janvier 2018 18:20:21
> >   Send the complete code as an attachment.
> > > On Jan 3, 2018, at 11:08 AM, Franck Houssen <franck.houssen at inria.fr>
> > >> Cc: "Matthew Knepley" <knepley at gmail.com>, "For users of the development
> > >> Envoyé: Mercredi 3 Janvier 2018 18:01:35
> > >>> On Jan 3, 2018, at 10:59 AM, Franck Houssen <franck.houssen at inria.fr>
> > >>> wrote:
> > >>> I need the exact opposite operation of an entry in the FAQ called "How
> > >>> do
> > >>> I
> > >>> collect all the values from a parallel PETSc vector into a vector on
> > >>> the
> > >>> zeroth processor?"
> > >>  You can use VecScatterCreateToZero() then do the scatter with scatter
> > >>  reverse.
> > > That's what I tried but got an error. Did I miss something ?
> > >>> tail vecScatterGatherRoot.cpp
> > >  zeroth
> > >  PetscFinalize();
> > >>> mpirun -n 2 ./vecScatterGatherRoot.exe
> > > Vec Object: 2 MPI processes
> > >  type: mpi
> > > Process [0]
> > > 1.
> > > Process [1]
> > > 2.
> > > Vec Object: 1 MPI processes
> > >  type: seq
> > > 1.
> > > 2.
> > >  type: seq
> > > -1.
> > > -2.
> > > [1]PETSC ERROR: [1] VecScatterBegin_MPI_ToOne line 161
> > > /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/utils/vscat.c
> > > [1]PETSC ERROR: [1] VecScatterBegin line 1698
> > > [1]PETSC ERROR: --------------------- Error Message
> > > [1]PETSC ERROR: Signal received
> > > [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > > for
> > > trouble shooting.
> > >>> Shall I use VecScatterCreateToZero "backward", or, use VecScatterCreate
> > >>> instead ? If yes, how ? (my understanding is that VecScatterCreate can
> > >>> take only parallel vector as input)
> > >>   This understanding is completely incorrect.
> > >>  Barry
> > >>> Not sure how to do this.
> > >>> Its not clear what you want. Do you want a seq vector duplicated on all
> > >>> procs?
> > >>> No. The seq vec should "live" only on the master proc. This seq master
> > >>> vec
> > >>> should be "converted" into a parallel vector. Not sure how to do that
> > >>> Do you want it split up? The short
> > >>> answer is, use the appropriate scatter.
> > >>>   Matt
> > >>> Franck
> > >>> In this example, the final VecView of the parallel globVec vector
> > >>> should
> > >>> be
> > >>> [-1., -2.]
> > >>>  type: mpi
> > >>> Process [0]
> > >>> 1.
> > >>> Process [1]
> > >>> 2.
> > >>>  type: seq
> > >>> 1.
> > >>> 2.
> > >>>  type: seq
> > >>> -1.
> > >>> -2.
> > >>> [1]PETSC ERROR:
> > >>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > >>> probably memory access out of range
> > >>> zeroth
> > >>> -lm;
> > >>> #include "petsc.h"
> > >>>  on
> > >>>  Vec locVec = NULL;
> > >>>  if (rank == 0) {
> > >>>    -1.);
> > >>>  &locVec);
> > >>>  SCATTER_FORWARD);
> > >>>  SCATTER_FORWARD);
> > >>>  if (rank == 0) {
> > >>>  zeroth
> > >>>  SCATTER_REVERSE);
> > >>>  SCATTER_REVERSE);
> > >>>  PetscFinalize();
> > >>> What most experimenters take for granted before they begin their
> > >>> experiments is infinitely more interesting than any results to which
> > >>> their
> > >>> experiments lead.
> > >>> -- Norbert Wiener
> > >>> https://www.cse.buffalo.edu/~knepley/
