[petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
Franck Houssen
franck.houssen at inria.fr
Thu Jan 4 02:31:05 CST 2018
I attached it in the very first mail.
Franck
>> more vecScatterGatherRoot.cpp
// How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
// ~> g++ -o vecScatterGatherRoot.exe vecScatterGatherRoot.cpp -lpetsc -lm; mpirun -n X vecScatterGatherRoot.exe
#include "petsc.h"
int main(int argc,char **argv) {
PetscInitialize(&argc, &argv, NULL, NULL);
int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size);
int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
PetscInt globSize = size;
Vec globVec; VecCreateMPI(PETSC_COMM_WORLD, 1, globSize, &globVec);
VecSetValue(globVec, rank, (PetscScalar) (1.+rank), INSERT_VALUES);
VecAssemblyBegin(globVec); VecAssemblyEnd(globVec);
VecView(globVec, PETSC_VIEWER_STDOUT_WORLD); PetscViewerFlush(PETSC_VIEWER_STDOUT_WORLD);
// Collect all the values from a parallel PETSc vector into a vector on the zeroth processor.
Vec locVec = NULL;
if (rank == 0) {
PetscInt locSize = globSize;
VecCreateSeq(PETSC_COMM_SELF, locSize, &locVec); VecSet(locVec, -1.);
VecScatter scatCtx; VecScatterCreateToZero(globVec, &scatCtx, &locVec);
VecScatterBegin(scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
VecScatterEnd (scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
// Modify sequential vector on the zeroth processor.
if (rank == 0) {
VecView(locVec, PETSC_VIEWER_STDOUT_SELF); PetscViewerFlush(PETSC_VIEWER_STDOUT_SELF);
VecScale(locVec, -1.);
MPI_Barrier(MPI_COMM_WORLD);
VecSet(globVec, 0.);
VecScatterBegin(scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
VecScatterEnd (scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
PetscFinalize();
----- Mail original -----
> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "Barry F. Smith" <bsmith at mcs.anl.gov>, "Matthew Knepley" <knepley at gmail.com>, "For users of the development
> version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Mercredi 3 Janvier 2018 18:20:21
> Objet: Re: [petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a
> Send the complete code as an attachment.
> > On Jan 3, 2018, at 11:08 AM, Franck Houssen <franck.houssen at inria.fr>
> >> Cc: "Matthew Knepley" <knepley at gmail.com>, "For users of the development
> >> Envoyé: Mercredi 3 Janvier 2018 18:01:35
> >>> On Jan 3, 2018, at 10:59 AM, Franck Houssen <franck.houssen at inria.fr>
> >>> wrote:
> >>> I need the exact opposite operation of an entry in the FAQ called "How do
> >>> I
> >>> collect all the values from a parallel PETSc vector into a vector on the
> >>> zeroth processor?"
> >> You can use VecScatterCreateToZero() then do the scatter with scatter
> >> reverse.
> > That's what I tried but got an error. Did I miss something ?
> >>> tail vecScatterGatherRoot.cpp
> > PetscFinalize();
> >>> mpirun -n 2 ./vecScatterGatherRoot.exe
> > Vec Object: 2 MPI processes
> > type: mpi
> > Process [0]
> > 1.
> > Process [1]
> > 2.
> > Vec Object: 1 MPI processes
> > type: seq
> > 1.
> > 2.
> > type: seq
> > -1.
> > -2.
> > [1]PETSC ERROR: [1] VecScatterBegin_MPI_ToOne line 161
> > /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/utils/vscat.c
> > [1]PETSC ERROR: [1] VecScatterBegin line 1698
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Signal received
> > [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
> > trouble shooting.
> >>> Shall I use VecScatterCreateToZero "backward", or, use VecScatterCreate
> >>> instead ? If yes, how ? (my understanding is that VecScatterCreate can
> >>> take only parallel vector as input)
> >> This understanding is completely incorrect.
> >> Barry
> >>> Not sure how to do this.
> >>> Its not clear what you want. Do you want a seq vector duplicated on all
> >>> procs?
> >>> No. The seq vec should "live" only on the master proc. This seq master
> >>> vec
> >>> should be "converted" into a parallel vector. Not sure how to do that
> >>> Do you want it split up? The short
> >>> answer is, use the appropriate scatter.
> >>> Matt
> >>> Franck
> >>> In this example, the final VecView of the parallel globVec vector should
> >>> be
> >>> [-1., -2.]
> >>> type: mpi
> >>> Process [0]
> >>> 1.
> >>> Process [1]
> >>> 2.
> >>> type: seq
> >>> 1.
> >>> 2.
> >>> type: seq
> >>> -1.
> >>> -2.
> >>> [1]PETSC ERROR:
> >>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> >>> probably memory access out of range
> >>> -lm;
> >>> #include "petsc.h"
> >>> Vec locVec = NULL;
> >>> if (rank == 0) {
> >>> SCATTER_FORWARD);
> >>> SCATTER_FORWARD);
> >>> if (rank == 0) {
> >>> zeroth
> >>> PetscFinalize();
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which
> >>> their
> >>> experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180104/dce9dd86/attachment.bin>
