[petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a parallel PETSc vector ?
Smith, Barry F. bsmith at mcs.anl.gov
Thu Jan 4 11:13:32 CST 2018
> On Jan 4, 2018, at 11:10 AM, Franck Houssen <franck.houssen at inria.fr> wrote:
> Do you reproduce the error at your side ? Or is the pattern I use wrong ?
   You should have received an email from me with a patch for PETSc code.  Yes I could reproduce, clearly our bug your code was fine.
  Barry
> Franck
> ----- Mail original -----
>> De: "Franck Houssen" <franck.houssen at inria.fr>
>> À: "Barry F. Smith" <bsmith at mcs.anl.gov>
>> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
>> Envoyé: Jeudi 4 Janvier 2018 09:31:05
>> Objet: Re: [petsc-dev] How do I collect all the values from a sequential vector on the zeroth processor into a
>> I attached it in the very first mail.
>> Franck
>>>> more vecScatterGatherRoot.cpp
>> // How do I collect all the values from a sequential vector on the zeroth
>> // ~> g++ -o vecScatterGatherRoot.exe vecScatterGatherRoot.cpp -lpetsc -lm;
>> mpirun -n X vecScatterGatherRoot.exe
>> #include "petsc.h"
>> int main(int argc,char **argv) {
>>  PetscInitialize(&argc, &argv, NULL, NULL);
>>  int size = 0; MPI_Comm_size(MPI_COMM_WORLD, &size);
>>  int rank = 0; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>>  PetscInt globSize = size;
>>  Vec globVec; VecCreateMPI(PETSC_COMM_WORLD, 1, globSize, &globVec);
>>  VecSetValue(globVec, rank, (PetscScalar) (1.+rank), INSERT_VALUES);
>>  VecAssemblyBegin(globVec); VecAssemblyEnd(globVec);
>>  VecView(globVec, PETSC_VIEWER_STDOUT_WORLD);
>>  PetscViewerFlush(PETSC_VIEWER_STDOUT_WORLD);
>>  // Collect all the values from a parallel PETSc vector into a vector on the
>>  zeroth processor.
>>  Vec locVec = NULL;
>>  if (rank == 0) {
>>    PetscInt locSize = globSize;
>>    VecCreateSeq(PETSC_COMM_SELF, locSize, &locVec); VecSet(locVec, -1.);
>>  VecScatter scatCtx; VecScatterCreateToZero(globVec, &scatCtx, &locVec);
>>  VecScatterBegin(scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
>>  VecScatterEnd  (scatCtx, globVec, locVec, INSERT_VALUES, SCATTER_FORWARD);
>>  // Modify sequential vector on the zeroth processor.
>>  if (rank == 0) {
>>    VecView(locVec, PETSC_VIEWER_STDOUT_SELF);
>>    PetscViewerFlush(PETSC_VIEWER_STDOUT_SELF);
>>    VecScale(locVec, -1.);
>>  MPI_Barrier(MPI_COMM_WORLD);
>>  VecSet(globVec, 0.);
>>  VecScatterBegin(scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
>>  VecScatterEnd  (scatCtx, locVec, globVec, ADD_VALUES, SCATTER_REVERSE);
>>  PetscFinalize();
>>> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
>>> À: "Franck Houssen" <franck.houssen at inria.fr>
>>> Cc: "Barry F. Smith" <bsmith at mcs.anl.gov>, "Matthew Knepley"
>>> <knepley at gmail.com>, "For users of the development
>>> Envoyé: Mercredi 3 Janvier 2018 18:20:21
>>>  Send the complete code as an attachment.
>>>> On Jan 3, 2018, at 11:08 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>> Cc: "Matthew Knepley" <knepley at gmail.com>, "For users of the development
>>>>> Envoyé: Mercredi 3 Janvier 2018 18:01:35
>>>>>> On Jan 3, 2018, at 10:59 AM, Franck Houssen <franck.houssen at inria.fr>
>>>>>> wrote:
>>>>>> I need the exact opposite operation of an entry in the FAQ called "How
>>>>>> do
>>>>>> I
>>>>>> collect all the values from a parallel PETSc vector into a vector on
>>>>>> the
>>>>>> zeroth processor?"
>>>>> You can use VecScatterCreateToZero() then do the scatter with scatter
>>>>> reverse.
>>>> That's what I tried but got an error. Did I miss something ?
>>>>>> tail vecScatterGatherRoot.cpp
>>>> zeroth
>>>> PetscFinalize();
>>>>>> mpirun -n 2 ./vecScatterGatherRoot.exe
>>>> Vec Object: 2 MPI processes
>>>> type: mpi
>>>> Process [0]
>>>> 1.
>>>> Process [1]
>>>> 2.
>>>> Vec Object: 1 MPI processes
>>>> type: seq
>>>> 1.
>>>> 2.
>>>> type: seq
>>>> -1.
>>>> -2.
>>>> [1]PETSC ERROR: [1] VecScatterBegin_MPI_ToOne line 161
>>>> /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/utils/vscat.c
>>>> [1]PETSC ERROR: [1] VecScatterBegin line 1698
>>>> [1]PETSC ERROR: --------------------- Error Message
>>>> [1]PETSC ERROR: Signal received
>>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for
>>>> trouble shooting.
>>>>>> Shall I use VecScatterCreateToZero "backward", or, use VecScatterCreate
>>>>>> instead ? If yes, how ? (my understanding is that VecScatterCreate can
>>>>>> take only parallel vector as input)
>>>>>  This understanding is completely incorrect.
>>>>> Barry
>>>>>> Not sure how to do this.
>>>>>> Its not clear what you want. Do you want a seq vector duplicated on all
>>>>>> procs?
>>>>>> No. The seq vec should "live" only on the master proc. This seq master
>>>>>> vec
>>>>>> should be "converted" into a parallel vector. Not sure how to do that
>>>>>> Do you want it split up? The short
>>>>>> answer is, use the appropriate scatter.
>>>>>>  Matt
>>>>>> Franck
>>>>>> In this example, the final VecView of the parallel globVec vector
>>>>>> should
>>>>>> be
>>>>>> [-1., -2.]
>>>>>> type: mpi
>>>>>> Process [0]
>>>>>> 1.
>>>>>> Process [1]
>>>>>> 2.
>>>>>> type: seq
>>>>>> 1.
>>>>>> 2.
>>>>>> type: seq
>>>>>> -1.
>>>>>> -2.
>>>>>> [1]PETSC ERROR:
>>>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>>> probably memory access out of range
>>>>>> zeroth
>>>>>> -lm;
>>>>>> #include "petsc.h"
>>>>>> on
>>>>>> Vec locVec = NULL;
>>>>>> if (rank == 0) {
>>>>>>   -1.);
>>>>>> &locVec);
>>>>>> SCATTER_FORWARD);
>>>>>> SCATTER_FORWARD);
>>>>>> if (rank == 0) {
>>>>>> zeroth
>>>>>> SCATTER_REVERSE);
>>>>>> SCATTER_REVERSE);
>>>>>> PetscFinalize();
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which
>>>>>> their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
