[petsc-dev] [Mike McQuaid] Re: [Homebrew/homebrew-core] PETSc: import from homebrew-science (#23598)
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Feb 25 20:22:32 CST 2018
  For each package that has an uninstall we run the uninstall. (that is for no packages since it is unlikely any have an uninstaller)
  For the other packages we can manually determine what they install and then list those items in the uninstall script. Not ideal but it will uninstall most of the items.
   Barry
> On Feb 25, 2018, at 8:17 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sun, 25 Feb 2018, Lawrence Mitchell wrote:
>>> On 25 Feb 2018, at 21:13, Jed Brown <jed at jedbrown.org> wrote:
>>> The try part of that commit (around os.remove) is necessary.  Also,
>>> "rmdir -p" provides a useful semantic in this context, but needs to be
>>> implemented manually in Python (or I don't know where that functionality
>>> is available in the standard library).
>> shutil.rmtree
> I think [in uninstall script] - we want to delete dirs only if the dir
> is empty.  [if not empty - it could contain files installed by a
> different package - as its common to install multiple packages in the
> same prefix]
> Also - thinking about it - its not clear if we can really do a proper
> uninstall - esp with --download-packages.
> Previously - 'make install' would also install the downloaded packages
> and we kept track of them for the uninstall script. But now - we let
> each package do its own 'make install' to the prefix location. But we
> don't have an 'uninstall' option for these externalpackages. [I don't
> know if any of them provide 'make uninstall' feature]
> Satish
