[petsc-dev] [Mike McQuaid] Re: [Homebrew/homebrew-core] PETSc: import from homebrew-science (#23598)
Jed Brown jed at jedbrown.org
Sun Feb 25 21:40:19 CST 2018
It would be pretty easy to provide the equivalent of CMake's
install_manifest.txt.
https://cmake.org/Wiki/CMake_FAQ#Can_I_do_.22make_uninstall.22_with_CMake.3F
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>   For each package that has an uninstall we run the uninstall. (that is for no packages since it is unlikely any have an uninstaller)
>   For the other packages we can manually determine what they install and then list those items in the uninstall script. Not ideal but it will uninstall most of the items.
>    Barry
>> On Feb 25, 2018, at 8:17 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Sun, 25 Feb 2018, Lawrence Mitchell wrote:
>>>> On 25 Feb 2018, at 21:13, Jed Brown <jed at jedbrown.org> wrote:
>>>> The try part of that commit (around os.remove) is necessary.  Also,
>>>> "rmdir -p" provides a useful semantic in this context, but needs to be
>>>> implemented manually in Python (or I don't know where that functionality
>>>> is available in the standard library).
>>> shutil.rmtree
>> I think [in uninstall script] - we want to delete dirs only if the dir
>> is empty.  [if not empty - it could contain files installed by a
>> different package - as its common to install multiple packages in the
>> same prefix]
>> Also - thinking about it - its not clear if we can really do a proper
>> uninstall - esp with --download-packages.
>> Previously - 'make install' would also install the downloaded packages
>> and we kept track of them for the uninstall script. But now - we let
>> each package do its own 'make install' to the prefix location. But we
>> don't have an 'uninstall' option for these externalpackages. [I don't
>> know if any of them provide 'make uninstall' feature]
>> Satish
