[petsc-dev] [petsc-users] Error during PETSc build on Edison
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Feb 1 10:45:57 CST 2018
Where are you getting these errors from? Some PETSc tests? Your own code?
> On Feb 1, 2018, at 10:32 AM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
> Ok, and how to get rid of runtime error like
> [0]PETSC ERROR: PETSc installed without X windows, Microsoft Graphics, OpenGL ES, or GLUT/OpenGL on this machine
> configure with --with-x=0?
> On Thu, Feb 1, 2018 at 8:06 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 1 Feb 2018, Amneet Bhalla wrote:
> > P.S: I was also mucking with cray-petsc. However, I could not use it
> > in my application. Cray-petsc is built with parallel hdf5 and some
> > of the libraries I need use serial hdf5. At runtime, the application
> > picks parallel hdf5 and the application crashes :-(. I tried this on
> > my laptop also and got the same result.
> > I think the only way out is to build my own version of PETSc without
> > (parallel) hdf5.
> Sure - its best to install petsc from source - for such special requirements.
> Satish
> --Amneet
