[petsc-dev] [petsc-users] Error during PETSc build on Edison
Amneet Bhalla
mail2amneet at gmail.com
Thu Feb 1 10:51:57 CST 2018
I am getting this if I run snes/examples/tutorial/ex3 manually in
interactive session.
[ex3 is a placeholder]
On Thu, Feb 1, 2018 at 8:46 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Where are you getting these errors from? Some PETSc tests? Your own code?
> > On Feb 1, 2018, at 10:32 AM, Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
> > Ok, and how to get rid of runtime error like
> > [0]PETSC ERROR: PETSc installed without X windows, Microsoft Graphics,
> OpenGL ES, or GLUT/OpenGL on this machine
> > configure with --with-x=0?
> > On Thu, Feb 1, 2018 at 8:06 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Thu, 1 Feb 2018, Amneet Bhalla wrote:
> > > P.S: I was also mucking with cray-petsc. However, I could not use it
> > > in my application. Cray-petsc is built with parallel hdf5 and some
> > > of the libraries I need use serial hdf5. At runtime, the application
> > > picks parallel hdf5 and the application crashes :-(. I tried this on
> > > my laptop also and got the same result.
> > > I think the only way out is to build my own version of PETSc without
> > > (parallel) hdf5.
> > Sure - its best to install petsc from source - for such special
> requirements.
> > Satish
> > --Amneet
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180201/21df06b7/attachment.html>
