[petsc-dev] [petsc-users] Error during PETSc build on Edison
Satish Balay
balay at mcs.anl.gov
Thu Feb 1 10:06:02 CST 2018
On Thu, 1 Feb 2018, Amneet Bhalla wrote:
> P.S: I was also mucking with cray-petsc. However, I could not use it
> in my application. Cray-petsc is built with parallel hdf5 and some
> of the libraries I need use serial hdf5. At runtime, the application
> picks parallel hdf5 and the application crashes :-(. I tried this on
> my laptop also and got the same result.
> I think the only way out is to build my own version of PETSc without
> (parallel) hdf5.
Sure - its best to install petsc from source - for such special requirements.
Satish
