[petsc-dev] Undefined symbols for _kspfgmresmodifypcksp_ and _kspfgmresmodifypcnochange_ when rebuilding
Patrick Sanan patrick.sanan at gmail.com
Wed Aug 22 04:04:34 CDT 2018
This happens fairly frequently when I try to switch/update branches of
PETSc (here invoked by building my own code, but the error message looks
the same with "make check"):
$ make
/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/bin/mpicc
-o runme.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
-I/Users/patrick/petsc-stagbl/include
-I/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/include
-I/opt/X11/include    `pwd`/runme.c
-Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
-Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind
 -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fstack-protector -fvisibility=hidden -g3  -o runme runme.o
-Wl,-rpath,/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib
-L/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib
-Wl,-rpath,/opt/X11/lib -L/opt/X11/lib
-Wl,-rpath,/opt/local/lib/gcc7/gcc/x86_64-apple-darwin17/7.3.0
-L/opt/local/lib/gcc7/gcc/x86_64-apple-darwin17/7.3.0
-Wl,-rpath,/opt/local/lib/gcc7 -L/opt/local/lib/gcc7 -lpetsc -lcmumps
-ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lumfpack
-lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig
-lsuperlu_dist -lHYPRE -lsundials_cvode -lsundials_nvecserial
-lsundials_nvecparallel -llapack -lblas -lparmetis -lmetis -lX11 -lyaml
-lstdc++ -ldl -lmpifort -lmpi -lpmpi -lgfortran -lquadmath -lm -lstdc++ -ldl
Undefined symbols for architecture x86_64:
  "_kspfgmresmodifypcksp_", referenced from:
      import-atom in libpetsc.dylib
  "_kspfgmresmodifypcnochange_", referenced from:
ld: symbol(s) not found for architecture x86_64
collect2: error: ld returned 1 exit status
I don't know why this is, exactly. Maybe it's more obvious from the
perspective of someone more expert on the Fortran interface, and we could
save some time reconfiguring (if these two symbols are really the only
issue).
 For these two symbols, the corresponding functions are declared but not
defined in
    src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c
"make deletefortranstubs" by itself doesn't seem to solve the problem. My
sledgehammer workaround is to do everything short of blowing away my entire
$PETSC_ARCH directory:
    make deletefortranstubs && make allclean && make reconfigure && make &&
make check
but I'm sure that's suboptimal, and in particular I'd like to avoid the
reconfigure.
Any useful community knowledge on this point?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180822/3b7ae61c/attachment.html>
