[petsc-dev] Undefined symbols for _kspfgmresmodifypcksp_ and _kspfgmresmodifypcnochange_ when rebuilding
Lawrence Mitchell lawrence at wence.uk
Wed Aug 22 05:35:06 CDT 2018
> On 22 Aug 2018, at 10:04, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> This happens fairly frequently when I try to switch/update branches of PETSc (here invoked by building my own code, but the error message looks the same with "make check"):
> $ make
> /Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/bin/mpicc -o runme.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3   -I/Users/patrick/petsc-stagbl/include -I/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/include -I/opt/X11/include    `pwd`/runme.c
> /Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/bin/mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3  -o runme runme.o -Wl,-rpath,/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib -L/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib -Wl,-rpath,/Users/patrick/petsc-stagbl/arch-darwin-stagbl-double-extra-debug/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -Wl,-rpath,/opt/local/lib/gcc7/gcc/x86_64-apple-darwin17/7.3.0 -L/opt/local/lib/gcc7/gcc/x86_64-apple-darwin17/7.3.0 -Wl,-rpath,/opt/local/lib/gcc7 -L/opt/local/lib/gcc7 -lpetsc -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lsuperlu_dist -lHYPRE -lsundials_cvode -lsundials_nvecserial -lsundials_nvecparallel -llapack -lblas -lparmetis -lmetis -lX11 -lyaml -lstdc++ -ldl -lmpifort -lmpi -lpmpi -lgfortran -lquadmath -lm -lstdc++ -ldl
> Undefined symbols for architecture x86_64:
>   "_kspfgmresmodifypcksp_", referenced from:
>       import-atom in libpetsc.dylib
>   "_kspfgmresmodifypcnochange_", referenced from:
> ld: symbol(s) not found for architecture x86_64
> collect2: error: ld returned 1 exit status
> I don't know why this is, exactly. Maybe it's more obvious from the perspective of someone more expert on the Fortran interface, and we could save some time reconfiguring (if these two symbols are really the only issue).
>  For these two symbols, the corresponding functions are declared but not defined in
>     src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c
> "make deletefortranstubs" by itself doesn't seem to solve the problem. My sledgehammer workaround is to do everything short of blowing away my entire $PETSC_ARCH directory:
>     make deletefortranstubs && make allclean && make reconfigure && make && make check
Does it work to do:
make allfortranstubs && make
In these cases?
I used to have to do this, until eventually I gave up and built without the fortran interfaces (may not be an option).
I tried to unpick the make rules so that if you built with fortran interfaces, the generation of individual interface would depend on the relevant C files, but gave up, because I couldn't see what was going on.
Cheers,
Lawrence
