[petsc-dev] tiny issues in test harness
Jakub Kruzik jakub.kruzik at vsb.cz
Tue Aug 14 05:05:41 CDT 2018
Hi all,
I started using test harness in PERMON and find out a couple of issues
with it.
1) multiple "args:" keywords in "test:" in "testset:" are ignored except
for the last "args:" keyword. See attached MWE and check it with
python2 ${PETSC_DIR}/config/testparse.py -t ex1.c -v 3
2) single quotes can't be used in "filter:"  keyword. E.g. filter: grep
'r =' generates
petsc_testrun ... 'grep 'r =''
resulting in filter being "grep r". Might be worth mentioning this in
dev manual and/or putting guards into parsing/petsc_testrun.
Best,
Jakub
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180814/09d02dd6/attachment.bin>
