[petsc-dev] Install location for MPIUNI mpi.h
Jed Brown
jed at jedbrown.org
Sat Apr 28 13:25:47 CDT 2018
Satish Balay <balay at mcs.anl.gov> writes:
> On Wed, 25 Apr 2018, Jed Brown wrote:
>> Bitbucket keeps saying "Something went wrong while creating your pull
>> request." but you can look at the branch
>> https://bitbucket.org/petsc/petsc/branch/jed/mpiuni-include/maint
>> @balay Can we simply remove the MPIUNI includes from MPI.py or should we
>> remove it later?
> Best to remove now - to check if there are issues?
> also Fix mpif.h usage code?
> There is also mpi.mod - that might need renaming [to comply with not installing in /usr/include?]
> So rename to mpiuni.mod? [and rename mpi.h to mpiuni.h etc?]
Renaming to include/petsc/mpiuni.h and the module probably makes sense
because ensuring correct path ordering is really delicate.
> Looks like this change is more of a 'master change'..
This branch started from 'maint', but does not need to be merged there.
>> What --download packages are supported when using
>> MPIUNI? I don't see any examples.
> Yeah - our tests are basic here. I don't remember if any externalpackages compiled with mpiuni
> Satish
