[petsc-dev] Install location for MPIUNI mpi.h
Wed Apr 25 19:19:35 CDT 2018
On Wed, 25 Apr 2018, Jed Brown wrote:
> Bitbucket keeps saying "Something went wrong while creating your pull
> request." but you can look at the branch
> https://bitbucket.org/petsc/petsc/branch/jed/mpiuni-include/maint
> @balay Can we simply remove the MPIUNI includes from MPI.py or should we
> remove it later?
Best to remove now - to check if there are issues?
also Fix mpif.h usage code?
There is also mpi.mod - that might need renaming [to comply with not installing in /usr/include?]
So rename to mpiuni.mod? [and rename mpi.h to mpiuni.h etc?]
Looks like this change is more of a 'master change'..
>  What --download packages are supported when using
> MPIUNI?  I don't see any examples.
Yeah - our tests are basic here. I don't remember if any externalpackages compiled with mpiuni
Satish
