[petsc-dev] nested timers transfers and reductions
Smith, Barry F.
bsmith at mcs.anl.gov
Sat Apr 7 10:36:53 CDT 2018
> On Apr 6, 2018, at 5:22 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Hi Barry,
> In our version of the nested timers, we had the functions
> PetscAdminSend, PetscAdminRecv and PetscAdminReduce. So I was
> expecting to find them at the end of the file
> petsc-3.8.4/src/sys/logging/xmllogevent.c but apparently
> you (re)moved them?
I do not remember why I would have removed these functions. If you can send a patch that would return them I would gladly try to get them working with PETSc again.
Barry
> We basically used these functions to fill the transfer(GiB/s) and
> reductions/s columns of the log just like we use PetscLogFlops to
> fill the compute(Mflops) column for our registered events.
> How should I do this with the petsc version of the nested timers?
> Chris
> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
> MARIN news: http://www.marin.nl/web/News/News-items/Application-of-potential-flow-methods-to-fast-displacement-ships-at-transcritical-speeds-in-shallow-water-1.htm
