[petsc-dev] nested timers transfers and reductions
Klaij, Christiaan C.Klaij at marin.nl
Mon Apr 9 04:37:49 CDT 2018
Hi Barry,
I've put the functions and fortran bindings in the attached
files. In our code, we use them as follows:
  CALL mpi_bcast(value,1,MPI_LOGICAL,iproc,MPI_COMM_WORLD,ier)
  IF(ier/=0) CALL tracing_abort('ERROR in bcast logical root !')
  IF (iproc==thisprocess) THEN
     ier = PetscAdminSend(1*(nprocesses-1),MPI_LOGICAL)
  ELSE
     ier = PetscAdminRecv(1,MPI_LOGICAL)
  END IF
I also noted that you changed the treshold from 0.1% to 0.01%, so
I tried to change it as a user with PetscLogSetThreshold, but
this function seems not accessible to users (and there's no
fortran version or manual page).
Chris
dr. ir. Christiaan Klaij  | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-november-naar-de-open-dag-in-Wageningen.htm
Sent: Saturday, April 07, 2018 5:36 PM
To: Klaij, Christiaan
Cc: petsc-dev at mcs.anl.gov; Koos Huijssen
Subject: Re: nested timers transfers and reductions
> On Apr 6, 2018, at 5:22 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Hi Barry,
> In our version of the nested timers, we had the functions
> PetscAdminSend, PetscAdminRecv and PetscAdminReduce. So I was
> expecting to find them at the end of the file
> petsc-3.8.4/src/sys/logging/xmllogevent.c but apparently
> you (re)moved them?
   I do not remember why I would have removed these functions. If you can send a patch that would return them I would gladly try to get them working with PETSc again.
    Barry
> We basically used these functions to fill the transfer(GiB/s) and
> reductions/s columns of the log just like we use PetscLogFlops to
> fill the compute(Mflops) column for our registered events.
> How should I do this with the petsc version of the nested timers?
> Chris
> MARIN news: http://www.marin.nl/web/News/News-items/Application-of-potential-flow-methods-to-fast-displacement-ships-at-transcritical-speeds-in-shallow-water-1.htm
Type: text/x-fortran
Desc: petsc_MPIadminF.F90
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180409/b7961593/attachment.bin>
Type: text/x-csrc
Desc: petsc_MPIadmin.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180409/b7961593/attachment-0001.bin>
