[petsc-dev] upcoming release and testing [v2]
Matthew Knepley
knepley at gmail.com
Thu Apr 5 21:36:18 CDT 2018
On Thu, Apr 5, 2018 at 10:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 6 Apr 2018, Matthew Knepley wrote:
> > Okay, I pushed fixes for everything I saw except:
> > 1) The weird ex56_1 bug. This is only due to feature-dmfield, and
> > its very strange that this logic error appears on only some
> > arches. Toby is looking at it, but it should not hold the other
> > branches.
> Ok
> > 2) The restart problem for ex12. This involves something I do not
> > understand about the test system, namely leaving files for another
> > test. Again, this does not happen everywhere, and the error is
> > just a missing file.
> Some of these test requirements are satisfied by a small subset of
> builds [so they don't get run in all the tests]
> > >> > origin/knepley/fix-dm-gmg
> > >> > origin/knepley/fix-ex62-tests
> > >> > origin/knepley/fix-fe-bd-integral
> > >> > origin/knepley/fix-fe-vector-spaces
> > >> > origin/knepley/fix-snes-ex69
> > >> > origin/tisaac/feature-dmfield
> I can try out a quick build of your branches on a few arches. [i.e
> with all the above branches except 'origin/tisaac/feature-dmfield']
Looks like Toby fixed this 2min ago.
Matt
> Satish
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/4cd54dfb/attachment.html>
