[petsc-dev] upcoming release and testing [v2]
Thu Apr 5 21:37:41 CDT 2018
On Fri, 6 Apr 2018, Matthew Knepley wrote:
> On Thu, Apr 5, 2018 at 10:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Okay, I pushed fixes for everything I saw except:
> > >   1) The weird ex56_1 bug. This is only due to feature-dmfield, and
> > > its very strange that this logic error appears on only some
> > > arches. Toby is looking at it, but it should not hold the other
> > > branches.
> > Ok
> > >  2) The restart problem for ex12. This involves something I do not
> > >   understand about the test system, namely leaving files for another
> > >   test. Again, this does not happen everywhere, and the error is
> > >   just a missing file.
> > Some of these test requirements are satisfied by a small subset of
> > builds [so they don't get run in all the tests]
> > > >> >   origin/knepley/fix-dm-gmg
> > > >> >   origin/knepley/fix-ex62-tests
> > > >> >   origin/knepley/fix-fe-bd-integral
> > > >> >   origin/knepley/fix-fe-vector-spaces
> > > >> >   origin/knepley/fix-snes-ex69
> > > >> >   origin/tisaac/feature-dmfield
> > I can try out a quick build of your branches on a few arches. [i.e
> > with all the above branches except  'origin/tisaac/feature-dmfield']
> Looks like Toby fixed this 2min ago.
Ok - will run the test on master+all the above and update you.
Satish
