[petsc-dev] upcoming release and testing [v2]
Satish Balay
balay at mcs.anl.gov
Thu Apr 5 21:34:42 CDT 2018
On Fri, 6 Apr 2018, Matthew Knepley wrote:
> Okay, I pushed fixes for everything I saw except:
> 1) The weird ex56_1 bug. This is only due to feature-dmfield, and
> its very strange that this logic error appears on only some
> arches. Toby is looking at it, but it should not hold the other
> branches.
Ok
> 2) The restart problem for ex12. This involves something I do not
> understand about the test system, namely leaving files for another
> test. Again, this does not happen everywhere, and the error is
> just a missing file.
Some of these test requirements are satisfied by a small subset of
builds [so they don't get run in all the tests]
> >> > origin/knepley/fix-dm-gmg
> >> > origin/knepley/fix-ex62-tests
> >> > origin/knepley/fix-fe-bd-integral
> >> > origin/knepley/fix-fe-vector-spaces
> >> > origin/knepley/fix-snes-ex69
> >> > origin/tisaac/feature-dmfield
I can try out a quick build of your branches on a few arches. [i.e
with all the above branches except 'origin/tisaac/feature-dmfield']
Satish
