[petsc-dev] upcoming release and testing [v2]
Thu Apr 5 20:26:49 CDT 2018
Thanks! I pushed some fixes to rmills/doc-add-rmills-to-user-manual.
Satish
On Fri, 6 Apr 2018, Richard Tran Mills wrote:
> Hi Satish,
> I decided that I don't have time to polish things as much as I'd like, so
> I'll make the significant user manual edit I had in mind after the release.
> It's something that can wait.
> I do have some minor doc changes to go into master for the release. I've
> tested these on my laptop to make sure they didn't break building the
> manual or man pages, but I suppose you should do a doc build cycle. Please
> merge in
> rmills/doc-rmills-performance-section-minor-edit
> rmills/doc-update-matcreateseqaijmkl-man-page
> With Barry's permission, I also made changes on these branches to add
> myself to the user manual author list and the website:
> rmills/webpage-add-rmills
> Could you please make sure that I made edits in all the right places for
> the above two branches, and then merge in for the release?
> Thanks,
> Richard
> On Thu, Apr 5, 2018 at 1:04 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > Sure - we can push doc changes without going through the test cycle [just
> > a doc build cycle]
> > thanks,
> > Satish
> > On Thu, 5 Apr 2018, Richard Tran Mills wrote:
> > > Hi Satish,
> > > I'm working on right now on some edits to part of the "Performance
> > Turning"
> > > part of the manual. If I can get these edits to a state I'm happy with,
> > I'd
> > > like them to go in the release, but I'm not sure if I will have them
> > ready
> > > before this evening.
> > > --Richard
> > > On Thu, Apr 5, 2018 at 5:58 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > > > All,
> > > > master builds have been clean for the past 2 days [except for some
> > > > timeouts]
> > > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> > > > 2018/04/04/master.html
> > > > However next is still not clean [slightly better than previous build]
> > 2018/04/05/next.html
> > > > [i.e the following branches still need fixes]
> > > > >   origin/knepley/fix-dm-gmg
> > > > >   origin/knepley/fix-ex62-tests
> > > > >   origin/knepley/fix-fe-bd-integral
> > > > >   origin/knepley/fix-fe-vector-spaces
> > > > >   origin/knepley/fix-snes-ex69
> > > > >   origin/tisaac/feature-dmfield
> > > > I have the following branches in queue for master [via next-tmp - these
> > > > builds will start soon]
> > > >  origin/balay/update-petsc4py-pre-39
> > > >  origin/dalcinl/mat-getset-ops
> > > >  origin/jczhang/fix-vecscatter-msg-logging
> > > > If next-tmp is clean - I can spin the release tarball later today
> > [after
> > > > merging them to master]
> > > > Or if there are other branches [that are clean] - that should go into
> > > > release - let me know.  We'll either have to wait one more day [for
> > > > these branches to go through next/next-tmp - or I can schedule another
> > > > next-tmp build later today (with additional branches) - if they are
> > > > ready by 3:30pm CST]
> > > > If I do not hear back about additional branches, and next-tmp is clean
> > > > - will spin the release tarball later today.
> > > > Thanks,
> > > > Satish
