[petsc-dev] upcoming release and testing [v2]
Richard Tran Mills
rtmills at anl.gov
Thu Apr 5 20:49:21 CDT 2018
Thanks, Satish! I notice also that, in the stanza beginning "When citing
PETSc, please do not refer to this document", Dave May is still missing.
Also, that stanza still refers to version 3.7 and 2016.
--Richard
On Thu, Apr 5, 2018 at 6:26 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> Thanks! I pushed some fixes to rmills/doc-add-rmills-to-user-manual.
> Satish
> On Fri, 6 Apr 2018, Richard Tran Mills wrote:
> > Hi Satish,
> > I decided that I don't have time to polish things as much as I'd like, so
> > I'll make the significant user manual edit I had in mind after the
> release.
> > It's something that can wait.
> > I do have some minor doc changes to go into master for the release. I've
> > tested these on my laptop to make sure they didn't break building the
> > manual or man pages, but I suppose you should do a doc build cycle.
> Please
> > merge in
> > rmills/doc-rmills-performance-section-minor-edit
> > rmills/doc-update-matcreateseqaijmkl-man-page
> > With Barry's permission, I also made changes on these branches to add
> > myself to the user manual author list and the website:
> > rmills/webpage-add-rmills
> > Could you please make sure that I made edits in all the right places for
> > the above two branches, and then merge in for the release?
> > Thanks,
> > Richard
> > On Thu, Apr 5, 2018 at 1:04 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > > Sure - we can push doc changes without going through the test cycle
> [just
> > > a doc build cycle]
> > > thanks,
> > > Satish
> > > On Thu, 5 Apr 2018, Richard Tran Mills wrote:
> > > > Hi Satish,
> > > > I'm working on right now on some edits to part of the "Performance
> > > Turning"
> > > > part of the manual. If I can get these edits to a state I'm happy
> with,
> > > I'd
> > > > like them to go in the release, but I'm not sure if I will have them
> > > ready
> > > > before this evening.
> > > > --Richard
> > > > On Thu, Apr 5, 2018 at 5:58 AM, Balay, Satish <balay at mcs.anl.gov>
> wrote:
> > > > > All,
> > > > > master builds have been clean for the past 2 days [except for some
> > > > > timeouts]
> > > > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> > > > > 2018/04/04/master.html
> > > > > However next is still not clean [slightly better than previous
> build]
> > > 2018/04/05/next.html
> > > > > [i.e the following branches still need fixes]
> > > > > > origin/knepley/fix-dm-gmg
> > > > > > origin/knepley/fix-ex62-tests
> > > > > > origin/knepley/fix-fe-bd-integral
> > > > > > origin/knepley/fix-fe-vector-spaces
> > > > > > origin/knepley/fix-snes-ex69
> > > > > > origin/tisaac/feature-dmfield
> > > > > I have the following branches in queue for master [via next-tmp -
> these
> > > > > builds will start soon]
> > > > > origin/balay/update-petsc4py-pre-39
> > > > > origin/dalcinl/mat-getset-ops
> > > > > origin/jczhang/fix-vecscatter-msg-logging
> > > > > If next-tmp is clean - I can spin the release tarball later today
> > > [after
> > > > > merging them to master]
> > > > > Or if there are other branches [that are clean] - that should go
> into
> > > > > release - let me know. We'll either have to wait one more day [for
> > > > > these branches to go through next/next-tmp - or I can schedule
> another
> > > > > next-tmp build later today (with additional branches) - if they are
> > > > > ready by 3:30pm CST]
> > > > > If I do not hear back about additional branches, and next-tmp is
> clean
> > > > > - will spin the release tarball later today.
> > > > > Thanks,
> > > > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/d70bd9bc/attachment-0001.html>
