[petsc-dev] upcoming release and testing [v2]
Richard Tran Mills rtmills at anl.gov
Thu Apr 5 19:09:39 CDT 2018
Hi Satish,
I decided that I don't have time to polish things as much as I'd like, so
I'll make the significant user manual edit I had in mind after the release.
It's something that can wait.
I do have some minor doc changes to go into master for the release. I've
tested these on my laptop to make sure they didn't break building the
manual or man pages, but I suppose you should do a doc build cycle. Please
merge in
rmills/doc-rmills-performance-section-minor-edit
rmills/doc-update-matcreateseqaijmkl-man-page
With Barry's permission, I also made changes on these branches to add
myself to the user manual author list and the website:
rmills/doc-add-rmills-to-user-manual
rmills/webpage-add-rmills
Could you please make sure that I made edits in all the right places for
the above two branches, and then merge in for the release?
Richard
On Thu, Apr 5, 2018 at 1:04 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> Sure - we can push doc changes without going through the test cycle [just
> a doc build cycle]
> thanks,
> Satish
> On Thu, 5 Apr 2018, Richard Tran Mills wrote:
> > Hi Satish,
> > I'm working on right now on some edits to part of the "Performance
> Turning"
> > part of the manual. If I can get these edits to a state I'm happy with,
> I'd
> > like them to go in the release, but I'm not sure if I will have them
> ready
> > before this evening.
> > --Richard
> > On Thu, Apr 5, 2018 at 5:58 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
> > > All,
> > > master builds have been clean for the past 2 days [except for some
> > > timeouts]
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> > > 2018/04/04/master.html
> > > However next is still not clean [slightly better than previous build]
> 2018/04/05/next.html
> > > [i.e the following branches still need fixes]
> > > >   origin/knepley/fix-dm-gmg
> > > >   origin/knepley/fix-ex62-tests
> > > >   origin/knepley/fix-fe-bd-integral
> > > >   origin/knepley/fix-fe-vector-spaces
> > > >   origin/knepley/fix-snes-ex69
> > > >   origin/tisaac/feature-dmfield
> > > I have the following branches in queue for master [via next-tmp - these
> > > builds will start soon]
> > >  origin/balay/update-petsc4py-pre-39
> > >  origin/dalcinl/mat-getset-ops
> > >  origin/jczhang/fix-vecscatter-msg-logging
> > > If next-tmp is clean - I can spin the release tarball later today
> [after
> > > merging them to master]
> > > Or if there are other branches [that are clean] - that should go into
> > > release - let me know.  We'll either have to wait one more day [for
> > > these branches to go through next/next-tmp - or I can schedule another
> > > next-tmp build later today (with additional branches) - if they are
> > > ready by 3:30pm CST]
> > > If I do not hear back about additional branches, and next-tmp is clean
> > > - will spin the release tarball later today.
> > > Thanks,
> > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180405/c19a98a9/attachment.html>
