[petsc-dev] No MatGetOperation() ?
Lisandro Dalcin dalcinl at gmail.com
Sun Apr 1 09:08:23 CDT 2018
Changed my mind a little about Mat{Set|Get}Operation() and fixed some
mess in MATSHELL:
https://bitbucket.org/petsc/petsc/pull-requests/915/add-matgetoperation-and-fixes-to-matshell/diff
On 1 April 2018 at 12:30, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Moreover, after a second look, I think MatSetOperation() is wrong. It
> should special-case  MATSHELL and dispatch to MatShellSetOperation()
> if the type match, otherwise bad things would happen.
> On 1 April 2018 at 12:08, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> Barry, you made the distinction MatSetOperation() vs. MatShellSetOperation().
>> 1) MatSetOperation() is misplaced, it should go somewhere in
>> src/mat/interface/matrix.c
>> 2) We should add MatGetOperation(), right? Should it just return the
>> routine set in mat-ops? Are you ok with this?
>> Lisandro Dalcin
>> Research Scientist
>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
>> 4700 King Abdullah University of Science and Technology
>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>> http://www.kaust.edu.sa
>> Office Phone: +966 12 808-0459
> Lisandro Dalcin
> Research Scientist
Lisandro Dalcin
Research Scientist
