[petsc-dev] No MatGetOperation() ?
Lisandro Dalcin
dalcinl at gmail.com
Sun Apr 1 04:30:47 CDT 2018
Moreover, after a second look, I think MatSetOperation() is wrong. It
should special-case MATSHELL and dispatch to MatShellSetOperation()
if the type match, otherwise bad things would happen.
On 1 April 2018 at 12:08, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Barry, you made the distinction MatSetOperation() vs. MatShellSetOperation().
> 1) MatSetOperation() is misplaced, it should go somewhere in
> src/mat/interface/matrix.c
> 2) We should add MatGetOperation(), right? Should it just return the
> routine set in mat-ops? Are you ok with this?
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
Lisandro Dalcin
Research Scientist
