[petsc-dev] PetscSF in Fortran
Mon Sep 25 05:12:50 CDT 2017
On Sun, Sep 24, 2017 at 8:57 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> On 25/09/17 13:37, Adrian Croucher wrote:
>> Actually it looks like DMGetDefaultSF() does already work in Fortran
>> though, and could be used to do the same thing.
>> Do you think that would be a reasonable way to do it?
> Hmm, I just tried it and it looks like the default SF produced by this
> function doesn't have any overlap. So that won't work for me.
> Guess I might need a Fortran interface for PetscSFSetGraph/PetscSFGetGraph
> after all. If you could put one it that would be great.
> Another simpler possibility that would work for my case is if there was a
> DMCopySF() function for copying the point SF from one DM to another. Up to
> you if you think that would be of enough general usefulness to warrant
> inclusion.
If you truly need the exact same SF for your grid, you should be able to
use DMGet/SetPointSF() since it will just reference count it for you. Then
the default SF is created automatically from the point SF. Does this work?
     Matt
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170925/b32fddcf/attachment.html>
